new 2014...cruise control question ?
Old 02-18-2014, 04:00 AM   #1
Hot2na [OP] Hot2na is offline
Hot2na is just really niceHot2na is just really niceHot2na is just really niceHot2na is just really niceHot2na is just really nice
Hot2na's Tacoma Gallery
I just picked up a 2014 4cyl 4x4 base model last night....no CRUISE...how can I figure out if it is pre wired for cruise? and how do I install...I already did a search...but I'm wondering if anything has changed for 2014...
BTW: its a regular cab and it has bucket seats & a Console....woo hoo !!!
Old 02-18-2014, 01:02 PM   #2
clcartwr is on a distinguished road
clcartwr's Tacoma Gallery
My 2014 access cab was pre wired...if I can find my installation instructions I can give you the pin numbers that the wires go to (at the ECM) and you could check to see if the wires are already there. I'll try to find them tonight. I had already half way wired my Rostra kit when I realized my truck was pre wired (Rostra support assured me no new Tacomas are pre wired!). Wish I would have known to begin with because I would have at least ordered the original Toyota clutch switch as the Rostra unit is a PITA! Ended up having to do a bunch a wire cutting and soldering to get it in. You shouldn't have to deal with that though since you have an automatic. You could just order the stalk and install it....if it works then you are pre wired
Old 02-18-2014, 05:32 PM   #3
Here is probably the easiest place to find the wires if you are pre wired (you can also look under the steering column but requires a little more work):
Locate the ECM by removing the glove box door. There will be a black connector(E22) to the right on the ECM...second from the bottom. Pull out this connector and check to see if there is a wire in pin 14(Brown I believe). If so this is your cruise switch wire. If this wire is in place all else should already be taken care of and the stalk should just be a plug and play kind of thing.
Old 02-19-2014, 04:59 AM   #4
That really helps,clcartwr....thanks
Old 02-19-2014, 07:41 AM   #5
Winker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shedWinker is one of the sharper tools in the shed
Winker's Avatar
Winker's Tacoma Gallery
I thought it was funny when I got my '13 RC 4x4 that cruise wasn't standard but bluetooth was. I didn't pack my brain when I bought mine so I just had the dealer install mine. I'm sure doing it yourself will save a few hundred dollars.
Old 02-21-2014, 09:07 PM   #6
AKA Threadkiller
BKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shedBKill is one of the sharper tools in the shed
BKill's Avatar
BKill's Tacoma Gallery
I certainly hope you have the wiring harness. I bought a new 2013 AC Prerunner in September. Part if the deal I negotiated was the installation of cruise control. They were a little miffed when they realized it didn't 't have the needed wiring harness and had to build one.
Old 02-22-2014, 07:58 AM   #7
If you buy the Rostra kit it will come with all the wiring you need if you aren't pre wired.
Old 02-22-2014, 10:22 AM   #8
Good to know , thanks
Old 03-01-2014, 08:46 AM   #9
Mrnurse is on a distinguished road
Mrnurse's Tacoma Gallery
I thought the new rc only came with bench seats
Old 03-01-2014, 03:05 PM   #10
my new R/C came with BUCKETS
Old 03-01-2014, 04:47 PM   #11
wfochris is on a distinguished road
wfochris's Tacoma Gallery
As I understand it, the auto has buckets while the stick has a bench.
Old 03-02-2014, 10:35 PM   #12
Ok. I'm not a huge fan of bench seats. Not that I don't like the fr-s but I am ready to be away from it. Too many issues with this one. And I have really grown fond of this lil pick up.
Old 03-03-2014, 07:10 AM   #13
Just a reminder : this thread is about cruise not seats......
Old 03-20-2014, 11:14 AM   #14
navin is on a distinguished road
Law Enforcement: Ret.
navin's Tacoma Gallery
Hi, I just bought a 2014 base 4x2 reg cab 5spd and want to add CC soon. Is the Rostra kit very easy to install? If it is pre-wired, is it just the stalk that needs to be added to the steering column or is a fitting needed on the throttle body too? I didn't see a pop out in the plastic for a stalk?
Manual trans needs a clutch switch too? What would be the consequence of skipping that, engine would rev if clutch disengaged? But brake would negate that, right?
Thanks!
Old 03-20-2014, 12:14 PM   #15
If you are pre wired the kit is very straight forward. Remove the air bag and install stalk (there is a stalk bezel you can buy to replace the plastic caps on side of steering wheel). The cruise works through the computer (drive by wire) so no throttle body mods. If you don't install the clutch switch the cruise will have a constant cancel signal since the switch opens to cancel cruise unless you tied the wires together. The Rostra instructions assume you aren't pre wired so you have to pick through them a bit.
Old 03-20-2014, 05:32 PM   #16
Thank you. I guess the full Rostras kit is the way to go, or if I'm prewired I can just buy the stalk and jump the clutch switch wires? Are they right at the pedal arm?
Is there a "how to" detailing the job somewhere on this forum?
Old 03-20-2014, 05:55 PM   #17
Yeah if you are pre-wired I would suggest buying just the stalk, stalk bezel, and clutch switch from Toyota. The Rostra clutch switch is a PITA and doesn't have the right connector so you have to splice into the stock wiring. I'm guessing the Toyota clutch switch would be a much simpler install. There are two wires with a connector taped up behind the fuse block in front of the clutch pedal arm. I would guess if you went through the trouble of getting under your dash to find these wires you might as well install the switch while you are under there....I have read of guys not installing the switch but I would advise to go ahead and install it.....
If you aren't pre wired the Rostra kit is the way to go because it includes all of the wires and pins you need to tap into the ECU etc.
There are several good right ups on various forums but not exclusively for the 2014 as some of the wires/connections are slightly different from what I can tell (if you aren't pre wired).
Old 03-20-2014, 08:25 PM   #18
iroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shed
iroh's Avatar
iroh's Tacoma Gallery
The thread in the 2nd gen section of toyotanation had a lot of good stuff, including instructions for the clutch switch that will be 95% of your install headache. When I put cruise in my 6 speed I remember dropping the panel down, then unbolting the fuse block and rotating it down enough to get my hand back there. You can't get to that area from below, at least not enough to do much.
Old 03-21-2014, 04:31 AM   #19
Ok, so I think I will be trading my troubled fr-s in for a tacoma r/c 4x4 auto. How do I know if it is prewired for cc? And I can just buy the stalk and brake switch? If it is prewired?
Old 03-21-2014, 04:33 AM   #20
See post #3
Cruise Control question Aramis 1st Gen. Tacomas 5 11-17-2012 12:55 PM
Cruise Control Question jmwoutdoors1 New Members 9 10-29-2012 08:04 AM
Cruise Control question jrdbrn Technical Chat 3 02-22-2011 11:08 AM
Cruise Control Question mcgiiver 2nd Gen. Tacomas 3 10-07-2009 07:37 PM
cruise control question cole47 1st Gen. Tacomas 3 05-22-2009 09:19 PM
