gas mileage with 31" tires
Discussion in '4 Cylinder' started by bobbyhill, Dec 20, 2014.
  1. Dec 20, 2014 at 10:47 PM
    bobbyhill
    bobbyhill [OP] Active Member
    mark
    Riverside CA
    08 2.7 5 speed
    Magnaflow muffler, push bar, 3 inch lift kit, 31 inch tires,icon rims15x8, black mess grill,32inch light bar
    I plan on putting 31 on my truck soon just wanted to know if any one new the difference I will get in mileage I currently get about 23mpg with stock tires and rims. I will be keeping my steelies (factory) with the 31's. Any help?
  2. Dec 20, 2014 at 10:54 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    What is the stock size for your truck? 4wd, prerunner, or 5 lug?
  3. Dec 20, 2014 at 11:05 PM
    bobbyhill
    mark
    Riverside CA
    08 2.7 5 speed
    215 75 15, 5 lug its a 2wd I'm probably gonna be putting on a 2 to 3 inch lift as well
  4. Dec 20, 2014 at 11:13 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    Well, I would expect you would lose 3 or so mpg. Maybe more with the lift. I am running 245 75 16s on my 5lug and get around 24 to 25 mpg, some times 26 or 27 if its alot of highway, but the new wheels are tires are lighter than the old. Pay attention to the weight of the larger tires and you can maybe save some gas.
    Also, check out the tire size calculator at the bottom of thd page. It will help you figure the difference in sizes.
  5. Dec 20, 2014 at 11:22 PM
    bobbyhill
    mark
    Riverside CA
    08 2.7 5 speed
    Thank you I will keep that in mind when I'm finding the tires I want. Do u still run stock rims?
  6. Dec 20, 2014 at 11:27 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    I swapped the steel stock ones for a set of 16s off a 1991 nissan 300zx turbo. Two sets of rears. They are the same patttern and I run hub rings.
  7. Dec 21, 2014 at 5:23 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I have a 2.7 5spd 4x4 AC and get a little over 22mpg with 265/75-16 LTX-MS2s. I have the lighter P-rated tires instead of the heavier LTs. I dropped a tenth or two of a mpg going from factory 245/75-16.
    Don't forget to calculate the wheel diameter difference when calculating mileage.
  8. Dec 21, 2014 at 5:36 AM
    Clearwater Bill
    Clearwater Bill Never answer an anonymous letter
    Billy
    Largo Florida
    '13 5 lug AC w/convenience package
    A few OE parts from fancy trucks
    You won't know the damage unless you either correct the speedo/odo to be accurate, or go to the effort of recalculating the actual miles driven every fillup.
    But I predict a significant drop. 15-20% at least.
    On a 2WD is it worth it? Is there a 'need'?
    Don't forget that the OE rims are very narrow, and won't properly accept a tire too wide. Not to mention the added bulk/weight will affect acceleration, braking, ride quality and handling. Un-sprung weight is the enemy of all those things.
  9. Dec 21, 2014 at 6:13 AM
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    I run 31s with a 3 inch lift... I get 15-17 mpg. I am assuming you are a 2.7 though, seeing you get 23 stock..
  10. Dec 21, 2014 at 1:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Funny, I thought of that this AM. Someone posted Mustang wheels fit, so I knew Z wheels would, as I was a 3x Z owner.
    But the TT wheels were wider in the rear, where the NA cars had the same size all around..........
    So are you running the same size tires on different width wheels?
    Regardless, I'd love to see a picture of them on your truck. I had mine polished. A lot of work on a sand cast wheel like that, but they sure perked up the red car..........
  11. Dec 21, 2014 at 1:35 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    IF you can find them OP, 265/75R15's are essentially the same size as a 31" but will save you some weight because they're a 4 ply instead of a 6 ply. The problem may be actually finding options in that size, since it's not as popular as it used to be.
    Also, I had 31's on my 99 3.4l 4x4 5 speed ext. cab and I averaged around 19. I got it as high as 22mpg once on summer gas feather footing it on back roads, but it was something of a fluke.
    Of course, it's apples to oranges since mine was a 4x4 and a 3.4 and yours is a 4x2 and a 2.7
  12. Dec 21, 2014 at 5:43 PM
    Indy
    Indy Master of all I survey.
    I'm getting around 18 with 31's and winter fuel.
  13. Dec 21, 2014 at 5:45 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    31's cost me about 1 mpg or so on my 09 4 cylinder prerunner
  14. Dec 21, 2014 at 8:06 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    They are two sets of the turbo rears
    EC7BC402-A0B0-4E6D-A193-803CD0CFB4A2_zps_4de2aa5e92538e10534e13a5678a30180006762c.jpg
  15. Dec 22, 2014 at 8:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Gotcha. Very cool. Got a shot that shows the whole truck? Looks like its white like mine, so now I'm really curious!
  16. Dec 22, 2014 at 4:44 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    19A1EFA0-C239-447D-B046-EFE19F6765D6_zps_8483b9262fcb88814924eba8d1d58b0b9fabc5f0.jpg
    Its silver streak mica....
  17. Dec 22, 2014 at 5:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    Thanks. Very cool. Bet you get lots of questions on 'what wheels are those!
  18. Dec 22, 2014 at 7:11 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    You know, you are the first to ask about them.....
  19. Dec 22, 2014 at 7:23 PM
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    well I am currently rocking 245-75 R16, which is stock for a 2014 regular cab 4x4 manual. the tire diameter is 30.5 inches. I am currently getting 18-20 mpg all city driving and thats running in 4x4 cause its winter. get about 20+ mpg in 2 wheel drive. so I am assuming you could achieve about the same mpg
