tacoma wont start help
Discussion in '4 Cylinder' started by dtaylor454, Dec 24, 2014.
  1. Dec 24, 2014 at 1:18 AM
    dtaylor454
    dtaylor454 [OP] Member
    kentucky
    98 tacoma.
    235/75r15 definity Dakota m/t Mickey Thompson classic 2's Painted Chevy blue
    I have a 98 Tacoma with the 2.7. Tonight I drove up to the gas station only 2 miles away then came back home. later on I tried to start the truck and nothing. It cranks and cranks but shows no sign what soever of starting. What I have done so far is check my efi fuses with a volt meter and they are all fine. Is there anymore fuses that I should check? Then loosened some sort of banjo bolt on the back of the fuel rail to see if I seen any fuel and there was some that leaked out. So does that rule out that I am getting fuel? Haven't checked spark yet. I'll have to wait till tomorrow when some one will crank it over for me. It just don't make sense to me how it ran fine then an hour later it does nothing. Any help would be appreciated I need this truck to go to work please help.
  2. Dec 24, 2014 at 2:02 AM
    Akron1
    Akron1 Member
    David
    Ohio
    20 TRD Sport 4X4
    No mods yet
    Wondering if you have a security system? On Toyotas with the security chipped key if you use a key that doesn't have the security chip it'll crank all day with out a cough.
  3. Dec 24, 2014 at 2:27 AM
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    Check your gas cap and make sure it's tight. It could be a fuel issue because if you pulled the banjo off the fuel rail it should have been under pressure unless you relieved it from the cap/system. Anymore details.
  4. Dec 24, 2014 at 11:30 AM
    dtaylor454
    kentucky
    98 tacoma.
    I'll try this. But it does not have an alarm system.
  5. Dec 24, 2014 at 11:34 AM
    dtaylor454
    kentucky
    98 tacoma.
    Truck has spark. Guess it is a fuel issue. Is the fuel pump in the tank? Any more fusses I should check?
  6. Dec 24, 2014 at 11:54 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Were the spark plugs wet with fuel after cranking it over?
  7. Dec 24, 2014 at 12:10 PM
    dtaylor454
    kentucky
    98 tacoma.
    No. I checked for that and they weren't wet. Thought that was odd so that's what led me to believe its fuel related.
  8. Dec 24, 2014 at 10:31 PM
    dtaylor454
    kentucky
    98 tacoma.
    Going to replace fuel pump. How hard is it to do. Any files would help
  9. Dec 24, 2014 at 10:37 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Honesty a big pain in the ass but, no special skills needed. My guess is that you filled the truck up at the fuel store? Remember to replace fuel filter at the same time.
  10. Dec 25, 2014 at 8:23 PM
    dtaylor454
    kentucky
    98 tacoma.
    I think I'm better off pulling the bed then dropping the tank correct?
  11. Dec 25, 2014 at 8:25 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    If you pull the bed, no need to drop the tank.
  12. Dec 25, 2014 at 8:29 PM
    tacomaluv69
    tacomaluv69 Active Member
    Alex
    Virginia Beach
    07 TRD Off Road SR5
    Bilstein 5100 3 inch lift front and rear Leer Camper shell 33 inch BFG k20s with 17x8 pro comp rims ARB Deluxe Steel Bumper
    Make sure everything is secure and tightly fastened. My 2nd gen would click and not start just because the battery terminals were loose/corroded. I hope you get things figured out!
    Best of Luck
  13. Dec 26, 2014 at 5:55 AM
    ecoterragaia
    Central Virginia
    Also might want to rule out a bad relay before digging in.
  14. Dec 26, 2014 at 6:04 AM
    Clearwater Bill
    Clearwater Bill Never answer an anonymous letter
    Billy
    Largo Florida
    '13 5 lug AC w/convenience package
    A few OE parts from fancy trucks
    What diagnostics have been done to prove the pump needs replacing?
    That's a lot of work (and cost) if that's not the root cause.
