Timing chain on 98 3RZFE 4x4
Old 01-21-2015, 06:27 PM   #1
KYTacoma98trd is on a distinguished road
KYTacoma98trd's Avatar
KYTacoma98trd's Tacoma Gallery
😡😡😡😡 I just started to tear down engine tonight! I've removed all brackets for a/c and alt. Also radiator, belts , pulleys and valve cover! I know the front chain is in good shape but secondary chain is what I belive is broke. So my question is pull engine or drop front end cause I need to do oil pan gasket and I guess I need to do valve job since I need to remove head also. How hard is it to pull engine alone and anyone got any tricks to make things a little easier!?
Timing Cover Leak Fix / Timing Chain Replacement W/ Pictures Tacoma 2005 2.7 VVT-i theduckbutter 2nd Gen. Tacomas 46 03-05-2015 11:28 PM
Toyota Timing Belt & Timing Chain Directory SamSin 2nd Gen. Tacomas 0 08-08-2013 05:46 AM
Timing? Timing chain? Valve? Bad motor? maza mike 1st Gen. Tacomas 5 03-24-2013 10:08 PM
Do all 2005 4x4 v6 tacoma have a timing chain? ttonon17 2nd Gen. Tacomas 5 04-01-2011 07:26 AM
Possible daily driver 98 Corolla - Timing chain broke. poynter Off-Topic Discussion 11 03-31-2011 09:12 AM
