#1 |
1.20.13
max tire size for 2.7
im thinking about doing a small lift for bigger tires, anyone know what the max size is for tires without doing a lift for the 2.7. without changing the gearing?
#2 |
Metal 'til I'm 90
I wanna say it's 265/75 without a lift on stock wheels.
__________________
#3 |
Do you have a base or prerunner? Manual or Auto?
#4 |
1.20.13
2008 sr5 4x4, 5spd man
#5 |
I got 265/75 toyo mt's ,and the truck is fine with no issues, Slight power loss from the weight however.
#6 |
Rocking your mom's world Since 1997
Same here: 265/75/16 BFG All Terrains.
Slight loss of power. Nothing major. Also consider clearance. I had to remove the front mud flaps because the tires rubbed them ever so slightly. Clearance will vary per brand and style though.
__________________
Texas Meet, November 20-22, NOW AT Hidden Falls Adventure Park
2006 Tacoma 2.7L 4x4 [My Build Thread] 4.56 Gears, ARB Lockers Front and Rear, Rear Suspension TSB, Secondary Charcoal Air Filter Removal, Bench to Bucket Seat Swap |
#7 |
265/75 mud tires here.
Pep boys cheap! only a little power loss / mpg loss but no problems with the size or overall performance. Definately gets me places my dunlops wouldn't dare...
__________________
08 Access Cab 4x4---2.7 I4 with 5 speed manual 07 4Runner Limited 4x4 If you ain't shifting, you ain't driving! http://www.theunknownsmc.com |
#8 |
I have been told by a local tire shop that 235/75 15's will be the max for the 15x6 wheels.
#9 |
I have 31 10.50 on mine and it does gine
#10 |
im with him, my truck does just fine with 31/10.50's!
#11 |
what about for the base 5 lug?
#12 |
285/60/18 NTGs lifted 2.5 fr/1.5 rr with 5100s/AAL....no more rubbin & no gear change. Heavy ass tire/rim combo. I'm sure there is some pwr loss but they came on the truck when I got it so unable to speak to how much pwr loss. Goes just fine tho, still gettin 20 mpg.
#13 |
Does things the hard way
#14 |
That's without a lift? No rubbing?
#15 | |
How do you find the billys set at 2.5??? Stiff at all?? Thinking of jacking mine up there and getting an aal or leaf pack |
#16 |
9th level dungeon master
lol.... you will need a lift for my size of tires!!! lt325/60r18
__________________
#17 | |
Avatar approved by 98tacomav6
NTGs are VERY light weight compared to other ATs. Exactly why I am getting them next |
#18 |
No lift and no rubbing with the 30 x 9.5's. To keep the tires from rubbing, you have to remove the small black box from the front wheel wells.
Guys that have the Readylift kit for the 5 lug can run 31 x 10.5. Check out this link for some posts about it over on Toyota Nation. Check out pages 2 and 3. http://www.toyotanation.com/forum/sh...=183794&page=2 |
#19 |
Uncivilized Creations Prez
2.5" lift 31x12.50x16 will fit. at least on a 1st gen
#20 | |
| Thread Tools | Search this Thread |
| Display Modes | |
| Max under bed spare tire size? | SuperD | Wheels & Tires | 3 | 03-07-2009 06:21 PM |
| 16x7 max tire size | JCMINIS | Wheels & Tires | 9 | 02-15-2009 05:02 PM |
| Max tire size | deputyjrp55 | Wheels & Tires | 3 | 12-22-2008 01:25 PM |
| max tire size | hondarida122 | Wheels & Tires | 1 | 12-11-2008 03:55 PM |
| Max Tire Size for 16x7 stock rim 05 Taco | mikenredding | Wheels & Tires | 5 | 01-29-2008 08:26 PM |
