#1 |
Lifts..6 inch or 3 inch???
Ok i have posted a few threads about this but still not quite sure what the answer is.. i have an 05 2wd 5 lug access cab..currently have 215/70/15 on it..plan on getting some 31's..i dont know much bout this stuff..i just know what i want..i was hoping to put a 6 inch pro comp lift on it but am not sure if that is even possible...i dont believe it is from what research i have done...but i have not been able to find out for sure...the guy that is selling it gave me this information.."The box says 57096B and the instructions say Part Number 57096"
here are a few pics of my truck...if this isnt possible then i will probably just go with a 3 inch..thanks in advance for the help.. ![]() ]![]() |
#2 |
Bear Down!
bump!
I know for the 5-lugger, most people are using the Ready Lift Kit. Fat Bob's Garage sell it for less than $200. The part number is 42275-SKL-5L
__________________
#3 | |
#4 |
Jag/Nole Fanatic!
Brings the thread to the top of the forum so more people can view it
#5 |
It just bumps the post to the top of the page so more people will see it
#6 |
Avatar approved by 98tacomav6
Personally, If I wanted to run 31" tires, I would go with a 3" lift since I think they would look puny under a 6" lift. Also stay away from spacers for your lift if you have the money
#7 |
i was a little late
#8 |
#9 |
International Airport
6 inch isn't possible on the 5 lugs, but that's ok because a three inch lift is perfect.
#10 |
Banned
#11 |
i think that is what i am going to end up doing...i dont have a lot of money..whats the difference..if i have to wait a little longer so i can save some money for better quality then i will...if i go with the 6 inch i would most likely end up putting bigger than 31's but in another thread i was told that if i was even able to put a 6 inch(which they didnt think i could) i would only be able to put 33's top..is that right?
#12 |
Banned
just remember... there are alot more expenses to a lift then just the lift and tires. you need to realize if you go to a 33 or bigger... a re-gear is in order. you dont have to of course... but when you grenade a transmission, you will remember these words im tellin you and be like.... shit... i shoulda listened. then you can call me up and ill re-gear your shit and do ur tranny swap... and i get my pockets filled with your coin.
#13 |
are there any other mods i could do to make a 6 inch possible sometime in the future...for now i think you are right bout the 3 inch because i am likeing some of the pics i see of others..i just want to know if in the future a 6 inch is a possibility..if you know what i mean
#14 | |
..thats seems to be what i have heard in my other threads
#15 |
#16 |
Banned
damn right i would... haha the bearing kit for your truck is like 2 bills... the gears are another 4 and then install and shimming is like 400 in labor. that just your axle... your trans... that would cost you another 5-600 in labor. not fun man.
#17 | |
Just a baby corn snake. His name is Stockholm.
#18 | |
#19 |
Banned
welcome to the world of automotive enhancement.
#20 |
you can do a readylift 3inch and a 3 inch body to equal a 6 that is what i am about to do, but with a bigger lift is less gas mileage you might just want to do a 3 and clear 31s easy 3 inch readylift http://readylift.com/c-107-tacoma-5-...-275f175r.aspx 3 inch body http://www.4wheelparts.com/Lift-Kits...2&t_pn=PER5603 the body lift is for my 2007 but the body mounts are the same so there is no difference hope this helps you |
| Thread Tools | Search this Thread |
| Display Modes | |
| Pics of all tacos with 3 inch lifts and 18's!!! | WW_FIREFIGHTER | 2nd Gen. Tacomas | 24 | 08-15-2009 05:48 AM |
| 1/2 inch block or aal that lift only 1/2 inch | KaliTaco | Suspension | 14 | 10-08-2008 11:36 AM |
| 3 inch Toytec with 3 inch body lift with 33s | BAMATOY | Suspension | 11 | 09-25-2008 09:24 AM |
| Need Pics of 3 inch lifts or higher. | caleb337 | Suspension | 6 | 06-20-2008 04:08 PM |
| 3 inch lifts | 99taco3150 | Suspension | 1 | 12-11-2006 02:40 PM |
