Complete 30k Maintenance
Discussion in '4 Cylinder' started by DanGer, May 17, 2009.
  1. May 17, 2009 at 9:33 AM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    1. Make/Replace cabin air filter
    2. Change Engine Air Filter
    3. Change engine Oil and Filter
    4. Change Rear Differential Fluid
    5. Change Transfer Case Oil (4x4 Only)
    6. Change Manual Transmission Oil (Manual Tranny Only)
    7. Rotate Tires
    8. Clean Throttle Body
    9. Grease and Torque Drive ("Propeller") Shaft
    Changing Spark Plugs: Since I have a 4 banger, I do not need to change my spark plugs yet. For those of you that do, here is a fantastic write up on how to do that.
    Total supplies needed:
    9qts of 75W-90 Oil
    6.1 qts of 0W-20 or 5W-20
    1 can throttle body cleaner
    1 toothbrush
    1 oil filter
    1 engine air filter
    1 air filter
    10mm socket
    24mm socket
    appropriate ratchets
    18" breaker bar
    oil catch pan
    a lot of rags!
  2. May 17, 2009 at 9:54 AM
    DanGer
    Here is what I did for the cabin air filter. The dealer quoted my dad $45 for a cabin air filter.
    So I bought a 16x20x1 furnace filter from Sears Hardware for $.89. I removed the old factory filter, and used it as a template.
    I cut the furnace filter to size, leaving two cardboard edges on each of the four new filters.
    Then I made frames on the remaining two sides of filters using duct tape:
    Now I have four air filters for $.89 + duct tape instead of one installed for $45. I bought the filter without wire because I was not positive what I could put in the truck. But I will change these more often then prescribed, because these don't seem to be the best quality.
    Now on to the glove box:
    First you have to remove the dampener (device that lets the glove box open slowly). There are two clips/pegs holding it in: One at the top attached to the dash, one at the bottom attached to the glovebox. The one at the top, I just pushed at the top of the dampener toward the glovebox itself. For the bottom one I pushed the clips at the end of the peg in while pushing out at the bottom of the dampener:
    Then you just flex the glovebox inward at the two pegs holding the top of it to the dash:
    Then the filter compartment is right in front of you. Just release the two clips:
    And open it up. Pull the filter out:
    And slide the new one in place:
    Now close it all up!
  3. May 17, 2009 at 11:05 AM
    DanGer
    Materials:
    AFE Pro Dry S filter
    One of the easiest installs! Pop your hood then find the air box at the front, passengers side of the compartment:
    Pop open the two metal clips on the front and carefully open the air box:
    Then remove the stock paper filter:
    and install the replacement filter:
    Close it back up and you are done!
    I am keeping the stock filter in storage for when I clean my aftermarket and let it dry overnight
  4. May 17, 2009 at 12:30 PM
    DanGer
    There is a very thorough write up here
    Just some notes to help you out on location:
    Get under the truck and locate the oil pan. It is toward toward the back of the engine compartment
  5. May 17, 2009 at 4:45 PM
    DanGer
    Great write up here
    My advice is to invest in one of these as tacomaman06 told me to do so. It makes life much easier, I trimmed the hose to keep it from kinking when in use and it helped a great deal.
  6. May 17, 2009 at 4:48 PM
    DanGer
    Materials/Tools:
    24mm breaker bar
    1-1.1 qts 75W-90
    oil pan
    The transfer case is extremely easy to change fluids. Just crawl under your truck and find the 2 piece driveshaft. Follow the driveshaft to the front, and you will find the transfer case.
    Locate the fill and drain plugs. Break them loose then finish removing with your hand. Remove the fill plug first, then the drain plug and be ready to catch the oil as it drains:
    While the oil is draining, clean off the plugs with a rag. Once it has drained, replace the drain plug and fill with just over a quart of oil:
    Once oil begins to overflow a bit, replace the fill plug and you are done!
  7. May 17, 2009 at 4:49 PM
    DanGer
    Materials/Tools:
    24mm Breaker bar
    ~2-3 qts 75W-90
    Oil pan
    Hand Oil pump/hose
    Crawl under your truck and find your transmission. On the drivers side about half way up and half way back you will find the 24mm fill plug. Break that lightly then remove by hand:
    Then on the passengers side, about half way back and near the bottom of the tranny, is the drain plug. Break that free, then finish removing by hand, prepared to catch the flow of used oil the plug is holding back:
    Once the oil is drained completely, re install the drain plug to ONLY 27 ft*lbs. Then fill with oil until the level is withing 0-5mm from the fill plug:
    Then replace the fill plug and you are done!
  8. May 17, 2009 at 4:56 PM
    DanGer
    For tire rotation, I followed this diagram provided to me by bobwilson1977:
    I recommend you take them to a place that will rebalance them as well. Check with them before you rotate, because they are usually willing to do it all for cheap.
  9. May 17, 2009 at 4:57 PM
    DanGer
    Thank you very much to tacomaman06 for walking me through this part via text message!
    Materials/tools needed:
    10mm socket
    Throttle Body Cleaner (I used generic but I recommend the Sea Foam Deep Creek)
    Philips head screw driver
    First pop your hood and locate the air box. Follow the rubber hose from the air box to the top of the engine.
    Loosen the clamp by unscrewing it with the philips head and wiggle the hose of of the plastic housing:
    Now locate the wire harness that is attached to the back of the plastic housing:
    Press the clip on top and unplug it:
    Next Locate the small, insulated hose on the back of the plastic housing.
    Press on the clamp arms to loosen it enough to unplug it:
    The last step in dis assembly is to remove the 3 10mm bolts holding the "home plate" shaped plastic housing to the top of the engine:
    Then loosen the clamp on the final air hose:
    And now you can clean the throttle body:
    You have to hold open the "butterfly" disc that is just inside the throttle body:
    Now spray the cleaner down in there and scrub away with a tooth brush. This pic shows the difference in the clean side, and the side still covered in carbon.
    Once you have it clean, I used some compressed air in an aerosol can (such as dust off) to help dry it out a little bit. Now just reattach all of your duct work and lines.
  10. May 18, 2009 at 3:28 PM
    DanGer
    Coming whenever I Find the right tools
  11. May 18, 2009 at 3:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great write up Dan!!! glad you got the tb cleaning squared away!
  12. May 18, 2009 at 4:17 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Good Job!
  13. May 18, 2009 at 4:19 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Nice write up. I can't wait to see the propshaft service. I've been curious about that one, although I'm not due for 7000 more miles.
  14. May 18, 2009 at 4:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well Done!
  15. May 18, 2009 at 8:00 PM
    DanGer
    Hey chris there is the throttle body pic i was talking about (the very last one).
    NAAC, I did mine at 26.5K. I figured I have a week off school I can do it and the first big maintenance package is better early than late!
  16. May 19, 2009 at 1:06 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    great write up!
  17. May 20, 2009 at 11:22 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Your engine: "Wash me! Wash me!" :)
  18. May 21, 2009 at 1:36 PM
    Fla-Fish
    Fla-Fish Member
    2006 Tacoma 2.7 4cyl 5spd 4X4 Access Cab
    Great write up.
    Now I just have to get out there and do it.
  19. May 21, 2009 at 6:56 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    good write up man!
  20. May 21, 2009 at 9:21 PM
    DanGer
    Thanks everyone, It took about 3x longer getting all the pics and writting it up, but I am hoping it will help some people out! I am hoping to finish tomorrow
    Ezriderga likes this.
