SecretSquirrel's 2005 Tacoma w/ All-Pro Bumper, Satoshi Grille, Cooper 305 STTs & more...
4 Cylinder Oil Change
Old 10-24-2009, 08:50 AM   #1
SSrUs will become famous soon enoughSSrUs will become famous soon enough
SSrUs's Avatar
SSrUs's Tacoma Gallery
I just did my first oil change at home on my '09. I went with Mobile 1 5W-20 synthetic and the 90915-YZZD3 Toyota filter. It was pretty easy, there's plenty of room under there to get at the drain plug and the filter.
My only complaint: the filter is straight up, but before I got it off I still had oil running down the length of my arm. Does anyone have a trick for getting the filter off without spilling oil all over?
__________________
Old 10-24-2009, 10:24 AM   #2
Tacoyota is a splendid one to beholdTacoyota is a splendid one to beholdTacoyota is a splendid one to beholdTacoyota is a splendid one to beholdTacoyota is a splendid one to beholdTacoyota is a splendid one to beholdTacoyota is a splendid one to behold
Tacoyota's Avatar
Navy: ex-Navy/Subs/sonar tech/sonar supervisor/uss Parche
Tacoyota's Tacoma Gallery
I had limited success with a plastic bag over the components to catch the oil. Place some absorbant shop towels on it. Use a latex glove to spin off the filter then just tried my best to minimize spillage. Also i pulled downward on the bag to make a channel, placed a hole in the bag over the waste oil collector.
Old 10-24-2009, 12:59 PM   #3
Avatar approved by 98tacomav6
DanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond reputeDanGer has a reputation beyond repute
DanGer's Avatar
DanGer's Tacoma Gallery
Both times I changed mine I just kept a steady hand to keep the filter level and it worked well enough for me
__________________
30K Maintenance Write up My build
Old 10-24-2009, 01:35 PM   #4
95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of95SLE has much to be proud of
Army: 34th SIG
95SLE's Tacoma Gallery
Use rubber shop gloves and unscrew the filter a little bit and let it drain into the oil drain pan.
Old 10-24-2009, 02:35 PM   #5
Takin' you to Jail
uood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud ofuood8 has much to be proud of
uood8's Tacoma Gallery
Exactly...once it stops draining...finish taking it off. If you have a lifted truck you don't even have to jack it up....easiest oil change ever.
Old 10-24-2009, 04:57 PM   #6
"SPACE FOR RENT SENT ME A PM"
wolfgang123 is a name known to allwolfgang123 is a name known to allwolfgang123 is a name known to allwolfgang123 is a name known to allwolfgang123 is a name known to allwolfgang123 is a name known to all
wolfgang123's Tacoma Gallery
i use a plastic bag over the filter
__________________
Old 10-24-2009, 10:36 PM   #7
Bear Down!
neslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond reputeneslerrah has a reputation beyond repute
neslerrah's Avatar
neslerrah's Tacoma Gallery
This is what I do.
This sounds like it should work. I'll give it a shot on my next oil change.
__________________
Old 10-25-2009, 09:57 AM   #8
Tacoyota's Avatar
pfft, steady hand, you Braggart. I can spill a glass of water just looking at it
Old 10-25-2009, 08:48 PM   #9
SSrUs's Avatar
Thanks for the ideas.....I'll give um a try
Old 10-27-2009, 05:27 PM   #10
OBJMS33 is on a distinguished road
OBJMS33's Tacoma Gallery
Just starting doing my first change on my truck. Thought I let it drain long enough. About ten minutes. Still had oil spillage before it came off the threads. Letting it drain more now before I try again. It did drain more from the plug when I broke the seal on the filter. Oil techs must hate this vehicle!
Old 10-27-2009, 05:33 PM   #11
Damn....not another best oil thread
BakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond reputeBakoTruck has a reputation beyond repute
BakoTruck's Avatar
BakoTruck's Tacoma Gallery
Just put some latex gloves on and unscrew the filter all the way off and put the filter on the oil collection pan. It's an oil change, your going to get oil on you.
__________________
Approximately 80% of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources.
Ronald Reagan
Old 10-27-2009, 05:40 PM   #12
Naw thats a messy ass design. I changed oil professionally in the past. You can stay clean if you want. I am doing this on my back at an apartment. Not a lot of room. That position give you almost no chance of getting it to the drain pain reasonably. I can't be making a huge ass mess in my spot. I was using my smaller diameter pan. Fixed now. If I was working in a shop and I had to wait that long for a car to drain I'd be in trouble. If your taking this to a shop for oil changes, your bringing some of your old oil home with you. I do work in a hospital and got gloves. Thought the problem was with drain time.
Old 10-27-2009, 06:25 PM   #13
Being the first time on that truck I will do a better job next time. Maybe I will lance a hole in the bottom next time
Old 10-28-2009, 12:12 AM   #14
Takin' you to Jail
use one of the big yellow antifreeze pans with the spout, it'll make life alot easier. Those little pans are for the birds.
Old 10-28-2009, 08:32 AM   #15
ubermx5 is on a distinguished road
ubermx5's Tacoma Gallery
Send a message via AIM to ubermx5
When on a dealer ship quick lube team we had to make thing clean.
So we got out cardboard, the cut it to fit so al the oil drained to 1 location.
Then once we has the right shape, we moved to plastic boards.
Melted and molded it to fit. So we could reuse it.
This was to cut down on Spraying the engain bay with Brake cleaner or a power washers. We have 15 minutes to get the oil change done and inspect the cars and truck. It was Quick lube..... not messy dirty lube...
Also if you has a mid 90's camery you can punch a hole in the filter and loosen it a bit and have all the oil drain back.
Plastic bags can work, but the oil needs to be cool and not freeway hot.
Rubber gloves help....
make sure to Fill your Spare tire with Air once every 3 months.
Old 11-07-2009, 09:52 AM   #16
NuovoTech is on a distinguished road
NuovoTech's Avatar
NuovoTech's Tacoma Gallery
Exactly how much oil does the 2.7L engine take after an oil & filter change?
Old 11-07-2009, 10:33 AM   #17
copernicus is on a distinguished road
copernicus's Avatar
copernicus's Tacoma Gallery
I did 6 quarts. Manual calls for 6.1 with filter change or 5.4 without.
Old 11-09-2009, 03:29 AM   #18
Doofus is on a distinguished road
Doofus's Tacoma Gallery
You can use a punch or screwdriver to knock a hole in the bottom of the filter to drain it first. Learned that trick from a diesel mechanic.
Old 11-09-2009, 04:41 PM   #19
DGXR will become famous soon enough
DGXR's Tacoma Gallery
I got a piece of cardboard about 8 inches wide and 18 inches long and curved it so it was like a half-pipe channel, and folded one of the ends over about 1/2 inch. Then I loosened the filter a bit (but still gasket-seated) and wedged the folded end of the cardboard channel up behind the filter, then unscrewed the filter enough to break the gasket seal so the leakage dribbled down the cardboard channel into the oil pan. Wiggled the oil filter to splash out any more oil, then left it alone for a few minutes then carefully removed the filter. Yes I got a little oil on my hand but the garage floor is still nice and clean. Hope this helps someone. Yes it is slightly awkward to access the filter depending on the ground clearance. Next time I will jack it up a little bit for some more working room.
Home > Tacoma Garage > 4 Cylinder
Display Modes
oil change and LSD rear diff change. flowmaster race series muffler? wwjdweldingman 2nd Gen. Tacomas 3 05-04-2009 08:41 AM
1st oil change and oil filter? clayj Technical Chat 23 04-04-2009 08:20 AM
Oil leak on front of engine. 4 cylinder... wheresthericego 1st Gen. Tacomas 5 03-08-2009 08:14 AM
1st Oil change - Cleaner/easier oil filter replace Stu Performance and Tuning 4 12-10-2008 04:47 AM
Oil Filter mess? on First oil change. mvega1969 2nd Gen. Tacomas 8 02-22-2008 02:01 PM
Copyright © 2009 Tacoma Forum
