97 2wd rear end specs?
Old 12-08-2009, 11:32 AM   #1
dylangunit [OP] dylangunit is offline
dylangunit is on a distinguished road
dylangunit's Tacoma Gallery
i have a 2wd 97 tacoma, its a 5 speed witha 2.4l im pretty sure my ratio is 3.42 right now, but im gettin ready to take it to a 4.10 ratio and put a different differential in it. i need to know everything about this rear end before i buy the parts like.spline count on axles, size of ring gear,and where to buy the parts.please help me my rear end is knocking and i need to fix it asap.
Old 12-08-2009, 11:36 AM   #2
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
http://home.4x4wire.com/erik/diffs/
Is this a 5 lug?
Old 12-08-2009, 11:40 AM   #3
yes
Old 12-08-2009, 11:40 AM   #4
:POOPCORN:
98tacoma27's Avatar
Marines:
Toyota Differential Code Decoder - Vehicles with 4Txxxxxx...VINs
First Position - Diameter of ring gear
A = 7.5"
B = 8"
Positions 2 & 3 - Ratio
01 = 3.42
02 = 3.58
03 = 4.10
04 = 4.56
05 = 3.15
06 = 3.91
Final Position - Differential type
A = 2 Pinion, Open
B = 4 Pinion, Open
C = 2 Pinion, OEM Limited Slip
Old 12-08-2009, 11:43 AM   #5
thanks alot
Old 12-08-2009, 11:44 AM   #6
:POOPCORN:
98tacoma27's Avatar
Marines:
Why are you going to 4:10's? Do you plan on lifting (bigger tires)?
Old 12-08-2009, 11:47 AM   #7
my vin is 4TANL42N3VZ259352
Old 12-08-2009, 11:47 AM   #8
no i want a faster take off for racing
Old 12-08-2009, 11:50 AM   #9
idk how to find the ratio and differentail type using the vin?
Old 12-08-2009, 11:51 AM   #10
:POOPCORN:
98tacoma27's Avatar
Marines:
There should be an axle code in your door jam sticker.
Old 12-08-2009, 08:03 PM   #11
i checked there too its the same vin that is on my dash
Old 12-08-2009, 08:12 PM   #12
chris4x4's Avatar
chris4x4's Tacoma Gallery
Can you take a pic of the sticker on the door jamb? Post it up, and we can disipher the code for ya.
Old 12-08-2009, 08:35 PM   #13
blackxpress is on a distinguished road
blackxpress's Avatar
Navy:
blackxpress's Tacoma Gallery
I'll be curious to know how it works out. How soon will you be you doing this? My 98 has a 3.42 2 pinion open diff and I've been thinking about going to a 4.10 LSD but I'm not sure I really want to. In my case I'm thinking it might help it do a little better job towing my boat, especially on steep ramps. I've been hesitating because the truck does a pretty good job as it is and gets 28 mpg hwy unloaded. It's my daily driver and I run on the hwy a lot so I don't want to risk screwing up my hwy performance and fuel economy unless I think it'll make a huge difference in towing performance. Keep us posted. Or, if others of you have made the same mod I'd like to hear about it.
Old 12-08-2009, 08:59 PM   #14
i just posted a pic of the vin off of my door in my pictures on here.
Old 12-08-2009, 09:00 PM   #15
and to blackxpress, it wouldnt get as good of fuel milage with the lower gear ratio. but it would definitely pull better.
Old 12-08-2009, 09:01 PM   #16
chris4x4's Avatar
Need the whole sticker. Cant see the gear code in that pic.
Old 12-08-2009, 09:01 PM   #17
ok sorry i got ill put it on here now
Old 12-08-2009, 09:06 PM   #18
chris4x4's Avatar
You have an A01A (lower right on the sticker)
7" 3:42 gears, 2 pinion open diff.
Old 12-08-2009, 09:08 PM   #19
do you know if my axles would fit in a 4wd rear end?
Old 12-08-2009, 09:09 PM   #20
chris4x4's Avatar
I dont think they will.
97 to 00 front end bubbaj847 1st Gen. Tacomas 3 05-21-2011 02:17 PM
97 4wd rear end help BigGreenTaco 1st Gen. Tacomas 16 12-06-2009 08:49 PM
Shocks for 97 2WD XCAB Karlg Buy / Sell / Trade 0 03-16-2009 07:48 AM
07 Sport Model Rear End Specs...???? hail-bop Command 2nd Gen. Tacomas 1 04-07-2008 10:47 PM
New to me 97 2WD Tacoma RaiderSix New Members 4 05-16-2007 10:13 AM
