1996 2.7L Low oil pressure light at idle!!!
Old 01-08-2010, 11:15 PM   #1
jgwelchjr [OP] jgwelchjr is offline
jgwelchjr is on a distinguished road
Navy: Petty Officer 2nd Class ET2 (SW)
jgwelchjr's Tacoma Gallery
Question 1996 2.7L Low oil pressure light at idle!!!
Recently after about a 45 minute drive, coming into town my oil pressure light blinked on at a red light (at idle). And then just above idle it goes back out. Did a few searches and didn't find this exact problem. It seems to have gotten worse as the weather has turned colder. Now tonight the light is staying on until about 1500 rpm and I pulled the oil fill cap off and noticed quite a bit of blow by. Is that normal, haven't noticed it before? The truck has 134,000 miles on it. And I also noticed that when starting it seems like the engine is not turning over as fast. Feeling more and more like I'll be putting along block in it. What do you guys think. Where is the oil pressure sender, I would like to put an actual gauge on it and see what the pressure is.
Old 01-09-2010, 08:28 AM   #2
yotakid98 is on a distinguished road
yotakid98's Tacoma Gallery
u could need to replace the oil pressure sender. check all seals make sure no leaks.
Old 01-09-2010, 08:29 AM   #3
blackxpress is on a distinguished road
blackxpress's Avatar
Navy:
blackxpress's Tacoma Gallery
Could be a combination of things. What weight oil are you running? If your oil is too heavy that would account for why it's turning over slow in cold weather. If your motor is idling a little on the low side and your oil is too heavy, you're not getting sufficient flow at idle. That can cause the sending unit to turn on the low pressure light. Also, at 134,000 miles your oil pump could be getting a little weak. I'm not sure but I believe the manual recommends 5W30 for that motor or 10w30 if the ambient temp is above 0F. Anything heavier than that can cause problems in the winter, especially if your oil pump has a little age on it.
Old 01-09-2010, 05:28 PM   #4
supralight is a splendid one to beholdsupralight is a splendid one to beholdsupralight is a splendid one to beholdsupralight is a splendid one to beholdsupralight is a splendid one to beholdsupralight is a splendid one to beholdsupralight is a splendid one to behold
supralight's Avatar
supralight's Tacoma Gallery
Most of the time, the oil pressure sensor is the problem.
Old 01-09-2010, 09:32 PM   #5
Thumbs down Installed manual gauge today.
This morning I installed a manual gauge and after a few minutes of idling the gauge shows around 2-3 psi and the light is on at this point. So I feel like the sender is doing it's job. (I put a tee in so I could see what pressure the light comes on at while looking at the gauge. So what now? How much blow by should I have at the oil filler cap? It seems like a lot to me? Maybe not considring the mileage. The engine sure seems to run good and does not use oil at all, it has no leaks anywhere. I'm thinking i should do a compression check on all cylinders, and if they turn out good then maybe I can just replace the oil pump. Oh yeah by the way about the most psi I can ge out of it at about 4000-5000 rpm is around 30 psi.
Could I have a clearance problem in some of the bearings? Like i said I have zero knocking and the truck seems to have good power. What about the cam, is it like a V-8 with pressurized bearing fit or is it just splash lubricated? Thanks for all your help.
John
Old 01-10-2010, 04:26 PM   #6
mbtech208 is on a distinguished road
mbtech208's Tacoma Gallery
I'm having the same problem with mine. It lost power on the highway, I pushed in the clutch and the engine died. Cranked over very slowly and finally started, but the oil light was on at idle and it's knocking. It's going to the dealer tomorrow.
Old 01-10-2010, 08:59 PM   #7
Continued low oil pressure!!!
That's exactly what happened to me, I'm just wondering if I can get by with putting an oil pump in or if I need a complete overhaul. Let me know what they say at the dealer.
Old 01-10-2010, 10:04 PM   #8
I'll let you know. I hope it doesn't need a new engine, it wouldn't even be worth fixing.
Old 09-06-2011, 08:48 AM   #9
jriveraboriqua is on a distinguished road
jriveraboriqua's Tacoma Gallery
The oil light goes on after I drive about 4-5 miles and stays on until I let it cool down. It is not overheating. The light goes off or flickers if I rev the engine a bit. Not sure if it is the oil or the oil pump...I have 156K miles.
Old 11-01-2014, 11:14 PM   #10
YoTaboss is on a distinguished road
YoTaboss's Tacoma Gallery
Same problem need help!!!
Any luck figuring out what your problem was my trucks runs fine but oil light comes on after a couple miles and stays on until I then it off and let it cool down plus the motor does not rev out and by that I mean it will not reach the rev limiter when you hold the gas down while the clutch is pushed in. Doesn't overheat and doesn't knock but after I while it does sound like maybe the top end isn't getting proper oil pressure and I have already replaced the oil pump but no changes
Please help!
Old 11-02-2014, 01:40 AM   #11
Wheeler in Training
Speedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shedSpeedytech7 is one of the sharper tools in the shed
Speedytech7's Avatar
Speedytech7's Tacoma Gallery
I have the same engine and I can confidently say that no matter what they seem to produce a lot of blow by. Other users and guys on Yotatech can confirm that. Mine sounds like another exhaust (just a lot quieter) when you take off the oil cap while it is running. However, generally the 3rz oil pump is a pretty solid unit so I would change the sender unit first. The oil pump on the 3rz can be changed if worse comes to worst.
Old 11-02-2014, 04:49 AM   #12
hotrod45 is on a distinguished road
Army: medic 5501 hospital
hotrod45's Tacoma Gallery
change the oil and filter more regularly. use high quality oil. no pennzoil. the engine obviously is worn. more than likely the main bearings. maybe use a little heavier oil. you don't have that much cold weather up there.
low tire pressure light JRoss Wheels & Tires 7 05-09-2011 07:05 PM
low pressure light esimmons Wheels & Tires 8 02-21-2011 05:18 PM
93 lumina, low oil pressure and knocking... darkturtleninja General Automotive 1 04-23-2009 10:44 AM
low pressure light on after new tires texasedition 2nd Gen. Tacomas 7 09-15-2008 07:08 AM
Low Pressure Light silvertaco408 2nd Gen. Tacomas 12 12-31-2007 09:28 PM
