Need advice on lifting my truck!
Discussion in '4 Cylinder' started by TRDChris, May 11, 2011.
  1. May 11, 2011 at 8:44 AM
    TRDChris
    TRDChris [OP] Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
    I have a 2001 Toyota Tacoma, I just got the truck a while back stock and I really want to lift it! It's a 4 cylinder 5 lug... I'm wondering how I can go about lifting it, what lift kits are available for me since I want to lift it at least 2.5 inches, I would greatly appreciate any help since I don't know too much about lifting!? [​IMG] [​IMG]
  2. May 11, 2011 at 8:49 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    http://www.tacomaworld.com/forum/suspension/149086-help-chosing-lift-kits.html
    you can try to use the search function on the site
    http://www.tacomaworld.com/forum/suspension/140293-need-help-lift-kit.html
    stolen from netmonkey.... from here..http://www.tacomaworld.com/forum/toytec-lifts/117712-help-choosing-toytech-lift.html
    dont get spacer lifts.
    the bilstien 5100's are the cheapest (0.85", 1.75", and 2.5" lift)
    the OME lift is next in cost (replaces the stock coils and shocks - 2.5" lift).
    the toytec coils are probably next in cost (1-3" lift).
    you will need a lift option for the rear. typical solution is the add a leafs with the 5100's.
    at 3" you really should get after market upper control arms that add in camber.
    the toytec ultimate lift kit inlcudes everything for a 3" lift except the UCA's
  3. May 11, 2011 at 11:28 AM
    TRDChris
    La Puente
    5 lugger
    Can I install the bilstien 5100 shocks with my stock coils?
  4. May 11, 2011 at 11:33 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    yes
  5. May 11, 2011 at 2:39 PM
    TRDChris
    La Puente
    5 lugger
    Thanks man I appreciate it.. I was lost
  6. May 11, 2011 at 2:45 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    ive got an 06 and i just lifted my truck 2.5 inches with 5100s and 1.5 AAL in the back and everything is stock except the shocks and it only cost around $300
  7. May 11, 2011 at 3:30 PM
    TRDChris
    La Puente
    5 lugger
    that's exactly what I want to do and that's a pretty good price I thought it would be more expensive... Did you get them installed or did you install them yourself? I was worried i would need new coils, I didn't know that you could install them with the stock coils.
  8. May 11, 2011 at 5:43 PM
    NetMonkey
    Geogetown, TX
    installing the AAL's are really easy, but taking apart the coils can be a pain. you can rent a spring compressor and do it yourself, but if you dont want to muscle with the compressor, you can take the coils to a shop and they can compress the spring and put on the new shocks. (they might charge $30 for each coil?)
    here is a pic of a set of compressors on a coil. when you crank them down, the screws can bend really bad and there is a risk of them popping off which could be very painful.
    dont forget to get an alignment after you lift your truck.
    good luck :)
  9. May 11, 2011 at 6:54 PM
    TRDChris
    La Puente
    5 lugger
    Thanks buddy I appreciate your help.. this helped alot
  10. May 12, 2011 at 9:49 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Lol @ the troll
  11. May 12, 2011 at 10:32 AM
    TRDChris
    La Puente
    5 lugger
    dont plan on going to high just some lift... I dont like it so low
  12. May 23, 2012 at 6:08 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Anyone know how much it would cost to have to have place install my bilstiens? they will be used with the stock coils.
  13. Aug 1, 2012 at 11:41 AM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    None of the lifts recamended will work on your truck since you have a 5 lug. Your options are limited. I'd go to the 5 lug section and talk with them. Your limited in options I.e. spacer lifts unless you want to drop some serious coin.
  14. Aug 1, 2012 at 11:43 AM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Woops just noticed how old the thread is...
