2nd Gen Cruise control
Discussion in '4 Cylinder' started by Redfish, Sep 20, 2011.
  1. Sep 20, 2011 at 6:57 PM
    Redfish
    Redfish [OP] Well-Known Member
    I think its garbage, anyone else agree? When I come to a overpass with a slight incline it will go from 2000 Rpm to 3000 + !! in a matter of seconds. There is no small increase in speed control, just a big jump. Once it almost hit 4000 rpm and I am worried something is going to break. Keep in mind this is in Florida. I get some weird looks because my exhaust makes a horrible noise with the sudden increase. This is my only complaint about the truck. I think its because the 4cyl has problems keeping speed on an incline while on cruise. I couldnt imagine what it would be like in the mountains, it probably wouldnt be worth using.
  2. Sep 20, 2011 at 7:12 PM
    Redfish
    Your are right but I just think Toyota should have come up with a different cruise control for the 4cyl. When I drive the same roads without cruise control I can manage to keep the engine from "flooring" and stay around 2000-2200 rpms. I dont think its good to jump from 2000 rpm to the mid/high 3's within seconds. Its a 4cyl truck not a GTR (and the GTR's tranny is broke from launch control's abuse.)
  3. Sep 20, 2011 at 7:19 PM
    Redfish
    All I am saying is its very startling when your driving down I-95 nice and easy and come to a overpass and BAM your engine is overvving and the exhaust sounds like some kids fast and furious honda civic.
  4. Sep 20, 2011 at 7:29 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Even my V6 does that some times. Normally it will start shifting and reving in certain spots. So I just drive it manually or just pay attention. Don't worry about it reving real fast you unless it is peggeg on the redline for a while.
  5. Sep 20, 2011 at 7:43 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I think that's the nature of automatics and cruise control on hills, there are lots of threads complaining about this. Toyota does this poorly.
    Another reason I'm glad I got the manual.
  6. Sep 21, 2011 at 7:25 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Cruise will try to maintain the set speed within +/- 2mph. Your "problem" is the result of your speed vs road conditions vs engine power in the current gear= not enough power to maintain.
    Solution=get used to it, or sell the cruise control to me:)
  7. Sep 21, 2011 at 7:43 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I like it with the manual tranny.
  8. Sep 21, 2011 at 7:50 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You must have an automatic. With the manual it works great if you know how to use it
  9. Sep 21, 2011 at 8:39 AM
    gt4som
    gt4som Active Member
    Nelson
    Tampa, FL
    This is my only complaint with my 2011 DC 2.7. I also live in Florida and this only happens on the overpasses. My way of dealing with this on the highway is if I set it to 75 and as I'm approaching a hill/overpass, I'll slightly increase the speed to prevent the tranny from down shifting. Kind of defeats the purpose of cruise control but oh well, not too many hills in florida lol.
  10. Sep 21, 2011 at 8:46 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Yes, glad to have manual because of this too but it isn't just a toyota thing. My mazda with sportauto does the same rev thing if using the accelerate button or on hills if in auto mode. Thankfully, I have manual mode with the + - shifting so if I use the cc I use manual mode on the tranny to avoid the revving thing. Doubting toyota will go sportsuto with this capability on the trucks tho.
  11. Sep 21, 2011 at 8:48 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Hahahahha. i think its fucking hilarious when my cruze control goes kamikaze!!
  12. Sep 21, 2011 at 12:18 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    X4 on the MT/cruise control combo. I love my CC.
  13. Sep 21, 2011 at 3:23 PM
    harleyg
    harleyg Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    That is my only complaint about the 2.7 I bought. Now I kick off the cruise approaching almost any hill, put it back on at the top. It is a pain, but I have gotten used to doing it.
  14. Sep 27, 2011 at 6:29 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    2.7 and the 5 spd manual, no shifts. No need to downshift on most hills on the freeway here in Oregon. I think the CC on that setup is great, if ther is a flaw , it might be that it SHOULD drop out of CC on the hill and force me to downshift just to be in the appropriate gear (4th) for some hills.
  15. Sep 27, 2011 at 10:00 AM
    sabre19
    sabre19 Member
    Phoenix, AZ
    2011 i4 Auto SR5 4x4
    GROM-USB2 w/ iPod and BT interface, OEM hitch and trailer harness, OEM tube steps, AFE Pro Dry S
    Yeah, it does suck. I'm guessing you have an auto tranny? My last vehicle was a 4-banger as well, but a stick, and it was only an issue when coming to a hill steep enough to bog the engine down. The cruse control in my Taco is full-on herp derp, and practically redlines the engine every time I come to a hill. Takes all the fun out of driving on the highway. Like you, when I manage the throttle manually, I can keep the tranny from dropping two gears all at once and redlining the engine fairly easily.
    Yeah, technically cruise is for flat terrain, but unless you live in the midwest, there's always gonna be the occasional hill. That stipulation is there probably to take responsibility away from those whose job it is to program algorithms for proper (read: smooth) cruise control throttle handling. Just my opinion.
  16. Oct 19, 2011 at 7:21 AM
    Redfish
    ya 4spd auto. It only does it at certain speeds. If Im going 70-80mph no problem but 65 oor below it sucks. My last truck was a ford and never had this problem.
  17. Oct 19, 2011 at 1:46 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    I do the same
  18. Oct 20, 2011 at 3:00 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    x3
    Cruise control is not designed to be efficient on hills and it will floor the throttle to maintain speed. Like someone else said, with the 4-cylinder automatic, there's just not enough power in high gear at 65mph to maintain speed without the tranny kicking down a gear or two.
  19. Oct 28, 2011 at 12:19 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, 300mm Broadway rear view mirror, LED brake lights, side markers, rear turn signals, plate lights, and interior lights. Flowmaster cat back exhaust, a cracked tail light that I fixed with some tape, all black grille, 15” Raceline 401B wheels, Goodyear 235/75/15 All Terrain Tires
    When I'm mountain driving I'm in 3rd and 2nd. Plus the heavy foot. But I can't hate this mod. I havnt done it yet but for a not so expensive DIY I can't wait to install it.
  20. Oct 28, 2011 at 1:00 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It worked well for me. The only hard part was the clutch switch. With an auto trans, install will be 1/2 hr, 15 min of which will be waiting for the airbag detonator to power down(after disconnecting the battery).
