-   -   2WD Offroad Help..Dif.Lock? huh (http://www.tacomaworld.com/forum/4-cylinder/18336-2wd-offroad-help-dif-lock-huh.html)
OFFROADCARWASH 11-06-2008 05:11 PM
Ive been hearing alot of 2wd dif. lock. What is that exactly...I have a 2000 prerunner2WD ..Do i have it? and does it effect me offroad?
-TRDMAN- 11-06-2008 05:34 PM
trd models have an electronic locker wich locks you rear axels together instead of lsd or open diff.!
Smurfio18 11-06-2008 05:34 PM
If your truck is stock then you probably don't. The rear diff. locker is a feature available on 2005+ tacomas and usually comes with ones with the Off road Package. The locker is intended to help you out if your in some mud or sand by giving both rear tires power opposed to the usual 1. You can add one to your 200 Prerunner but your gonna have to buy the rear diff kit and install a switch in your dash to get the same effect.
asdf 11-06-2008 06:23 PM
my 2003 prerunner came stock with rear dif lock
-TRDMAN- 11-06-2008 06:24 PM
Is it a trd!?!
Janster 11-06-2008 07:06 PM
Yeah...the "TRD OFFROAD" trucks all come with the e-locker (fulltime locker). 1st gens & 2nd gens....
