Wont shift into gear
Discussion in '4 Cylinder' started by Super Heros Inc, Oct 23, 2011.
  1. Oct 23, 2011 at 4:24 PM
    Super Heros Inc
    Super Heros Inc [OP] New Member
    Preston
    Dover, DE
    06 tacoma
    when i first start it up it moves like it should into all the gears but after I let the clutch out that first time and reengage it, the stick doesn't want to go into any of the gears sometimes if I pump the clutch while pushing the stick it will go in but with much resistance... does anyone have any ideas of what could be wrong? its a 2006 tacoma manual transmission with about 80000 miles, all fluids are good and nothing is leaking
  2. Oct 24, 2011 at 8:50 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Clutch is hydrolic, so looking for fluid around the slave cylinder on air in the line is more likely especially if this was a sudden thing. Get under and look for anything wet around side of trans. Could also be a failed seal inside which you wont see.
