Yellow creamy substace found under oil cap
Discussion in '4 Cylinder' started by CATpoweredYota, Feb 22, 2012.
  1. Feb 22, 2012 at 7:42 PM
    CATpoweredYota
    CATpoweredYota [OP] Member
    Stevo
    KENTUCKY
    09 PreRunner Acess Cab Speedway Blue
    16" Chrome Moto Metals Toyota TRD skid plate 3"Toytec lift 265/75/16 Nitto Terra Grapplers
    I recently bought and put on a K&N cold air intake but the directions didnt call for me to install a PCV valve on the new rubber hose coming from the valve cover to the chrome intake. In conclusion ive drove it in ohio for about a month so far and i recently found a yellow creamy liquid under the oil cap should i install a pcv valve? i know if it doesnt reach operation temp it leaves this under the oil cap think the PCV valve would fix my problem?
  2. Feb 22, 2012 at 7:46 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    thats just condensation..The engine isnt reaching op. temp for long enough to burn moisture off. Installing the pcv probably wont help
  3. Feb 22, 2012 at 7:46 PM
    OffroadToy
  4. Feb 22, 2012 at 7:59 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    man yogurt :rofl:
  5. Feb 22, 2012 at 9:20 PM
    CATpoweredYota
    Stevo
    KENTUCKY
    So just get the truck to operating temp and dont put a PCV valve in the line
  6. Feb 23, 2012 at 12:12 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Someone spooged in your fill tube. Ewww.
  7. Feb 23, 2012 at 12:13 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    No, his truck just came.
  8. Feb 23, 2012 at 9:05 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    No, you need to get the truck up to operating temperature and then drive it for more then 15-30 minutes each time(depending on moisture amount) to allow time for moisture to burn off. If you only drive it for 5- 10 miles at a time the moisture cant burn off operating temperature or not. Again this isn't a concern either way, so don't worry about it.
    Note: This is perhaps an indicator to change the oil a little more frequently. Shorter trips are harder on engine so shorten the oil change frequency to match. This won't get rid of the substance though.
  9. Feb 23, 2012 at 9:10 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Your truck is going to explode. Stop on the side of the road and immediately turn it off.
    Water in your oil is a big problem :D
  10. Feb 23, 2012 at 9:11 AM
    XXXX
    sKiP
    05 Prius
    lolz....at "cold air" warm air intakes :D
  11. Feb 2, 2013 at 5:21 AM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    The white substance is similar to mayonaise. Moisture condenses in your crankcase. The running engine with crankcase oil is like a food mixer and produces the white substance. The above comments about getting up to full, normal, engine temperature are correct. Sometimes I just enjoy a drive in my pickup extending some around town errands. Enjoy your truck.
  12. Feb 24, 2013 at 4:37 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Agree. People are finally starting to catch on these CAIs do nothing. Often make the intake air warmer.
    A snorkel is the closest thing you'll get to a true cold air intake. Short of cooled intake piping.
  13. Feb 24, 2013 at 4:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This and the other comments about not getting the truck up to temperature are not accurate. I've noticed that yellow creamy crap on my filler neck for the last few oil changes now. I've always had it, but the last 3 changes have been a lot worse. I drive 25 miles each way to work every day and do very, very, very few short trips. It may be condensation, but the cure is not getting the truck up to temperature.
