-   -   engine cutout only on bumps? (http://www.tacomaworld.com/forum/4-cylinder/213484-engine-cutout-only-bumps.html)
yota new.o 04-05-2012 12:56 PM
like the title says my engine will cut out briefly if i go over a bump in the road and at first start up you give it any as and it sputters almost dies but then comes back up to rpm, sometimes when it cuts out i lose sound to my stereo it does not turn off bu the music stops im baffled does any one have an answer. ive checked battery cables, dist. cap, rotor, plugs wires, fuel pump connector, fuel filter
yota new.o 04-05-2012 01:05 PM
*bump* any info at all?
Hard 04-05-2012 01:42 PM
I think you are on the right track, somthing is loose. It could be a broken wire that is not making good connection, but that is much harder to find. I would start playing with things while the engine is running and see if you can kill it by jiggling a conector or harness.
wolftree 04-05-2012 01:52 PM
From your description, focus your search around your ignition switch and wires leading to it.
yota new.o 04-06-2012 12:41 AM
was also thinking they said when my lift got done the battery died on them could it be my battery is slowly taking a dump and it just happens to mess something up with it when i hit a bump this is getting very frustrating thanks for the answers guys gunna try them tomorrow
OZ-T 04-06-2012 12:42 AM
I had a similar issue on my old truck , turned out to be a loose main ground
yota new.o 04-06-2012 12:48 AM
definatly will check main wires tomorrow then drive down to autozone and test battery and alternator
yota new.o 04-06-2012 11:46 AM
well main wires are just fine, tested battery it was bad took connectors off tested it again and it was good, replaced the connectors and now the problem is worse, but now it acts like its starved for fuel. the is really getting irritatiing im lost guys i need some help
BAMFTACO 04-06-2012 11:51 AM
Definetly a wire is loose somewhere are seeing any codes poping up
yota new.o 04-06-2012 11:57 AM
nope no codes just checked that, when i first start it and rev it, it sputters untill it gets into higher rpms, thinking about replacing fuel filter and see what that gets me
BAMFTACO 04-06-2012 12:27 PM
I think I might no what's going on now check your ground and power on the fuel pump because thats what to my buddy's jeep it would stall out every time it would hit a bump and it was the ground wire near the fuel getting loose and starving the engine
Gorillazrus 04-06-2012 11:35 PM
I had a similar issue with an old s-10 I had no power, boging down, missing ect. And it turned out that their was an ignition wire to my distrubitor that had chafed through and was grounding out when ever it touched anything metal, could be that when they did your lift they might have pinched a wire some were and it's shorting out.
yota new.o 04-07-2012 01:59 AM
thanks guys for the responses im going to dig into it tomorrow and hopefully solve this issue, looking at it today i found my throttle body was loose and was missing a bolt, a ground wire was not connected and my cap had some crap ont he points, fixed those issues but no change in truck
wolftree 04-07-2012 07:28 AM
Did you clean the battery post terminals and cables when you took them off the battery?
Steves104x4 04-07-2012 07:44 AM
Check engine ground wires that attach to the frame. 9x out of 10 they are corroded off. I was given (for free!) an old truck that didn't run; brought it home and sure enough the engine ground wire to the frame was corroded off. I sanded clean the frame, put new ground wire end on, gave a Hail Mary and it started right up and ran like a dream.
Also (just for fun) check the engine wiring isn't burned or pinched especially around the EGR valve.
Hunting idle is also a sign of vacuum leaks. Check the little vacuum hoses for deterioration and cracks. I'd hit the auto store and buy a roll of new vacuum hose and start replacing them.
Also, make sure your EGR valve moves freely by pushing up on the diaphram on the underside space provided on the valve. If it does not move freely, buy a new EGR valve.
yota new.o 04-07-2012 05:55 PM
ok just finished putting in a new cap rotor ign coil and fuel filter. it no longer cuts out on bumps it has good acceleration and good speed but now it misses at 1500 rpm everygear does it when we excelerate and decelerate. and it's a mild miss what do you guys think?
Steves104x4 04-07-2012 06:23 PM
I would replace the ignition wires and plugs if you haven't already.
yota new.o 04-07-2012 06:39 PM
will do tomorrow
yota new.o 04-08-2012 12:29 AM
any other suggestions
KalamaKid 04-08-2012 12:32 AM
Possible the bearings are shot on your alternator
Go down and tug on the rotor shaft and see if you have any play
