-   -   What's a good oil filter (http://www.tacomaworld.com/forum/4-cylinder/218910-whats-good-oil-filter.html)
Stuie 05-08-2012 12:20 PM
I just got my 5 lug Tacoma and want to change all the fluids to royal purple but iam not sure witch oul filter to go with ? My plan for the truck will be tint the windows 3 inch lift wheels and tires .
The1youluv2hate 05-08-2012 12:24 PM
Use Toyota oil filter and post pic of your tiny windows
91r100gs 05-08-2012 01:46 PM
The Toyota OEM
Purolator Pure One PL10241
Denso First Time Fit 15-1002 (Denso makes Toyota OEM, but this one is made better. Available on Amazon)
These are some good $5 to $7 filters.
If you want to do the 10K Oil Change with Royal Purple 0w-20 use a Mobil 1, Royal Purple, or K&N filter in the $10 to $15 price range.
All of the mentioned filters are very good to great filters.
Happy Motoring:burnrubber:
SVHANC 05-08-2012 04:58 PM
The Purolator Pure One PL20195 is an upsized filter that I run on mine. I just feel better with a bigger filter with more surface area for filtering.
I run 7500mile Oil Changes, so every little bit helps.
traknatrak 05-15-2012 09:32 AM
I got a 99 tacoma regular cab. I have 218600 miles on it. Previous owner didn't know whether she used a conventional oil or synthetic. I want to change the oil to a synthetic. Is that good or bad? Will it do more harm than good?
4Wheelin4Banger 05-15-2012 09:39 AM
There is a thread on here where chris4x4 tested and took apart a lot of oil filters and Toyota was the best.
Sticky: Toyota Oil Filter (Made in Thailand) vs. the competition........
motorking 05-23-2012 05:40 AM
oil filters
The FRAM Ultra filter is the best filter for synthetic oil changes. It has a stainless steel screen with two layers of synthetic filter media. 15000 mile capacity (highest in the industry) and 99% efficiency tested to ISO 4548-12 test specs. It has steel end caps and has a high flow bypass and silicone antidrainback valve. All for around 8 bucks.:D
