Pop sound from the tailpipe?
Discussion in '4 Cylinder' started by 4X4SUPERWHITE, May 13, 2012.
  1. May 13, 2012 at 9:36 AM
    4X4SUPERWHITE
    4X4SUPERWHITE [OP] Active Member
    I have a 2011 with a 2.7L, with less 10k., when I first start it in the morning I can hear a soft pop sound from the tailpipe:(. It doesn't do this very first time in the morning. Is this a common thing or should I be worry? :confused:Has anybody had this problem?
  2. May 13, 2012 at 9:37 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    happens all the time, nothing to worry about :) just another one of those 4 banger things we live with
  3. May 13, 2012 at 9:43 AM
    4X4SUPERWHITE
    Ok,thanks. I just don't want it, to get any worse down the road.
  4. May 14, 2012 at 7:01 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    When I first got my truck, as I started it up to back out of the garage, my wife would say "it sounds like your truck is backfiring"...
    Its normal, and I believe it has something to do with emissions... something about trapped gases in the converter or something like that as I remember...
  5. May 14, 2012 at 7:10 AM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    We have two identical 2009 2.7's at work. Both do it. One has around 40K on it, the other 60K. No problems with either one of them.
