-   -   Toppers and gas mileage (http://www.tacomaworld.com/forum/4-cylinder/219851-toppers-gas-mileage.html)
My4x4Tacoma 05-14-2012 06:05 PM
Now have a little over 1400 miles on my 2012, regular cab, 4x4, manual transmission. I kept speeds pretty low, below 60 most of the time and drove backroads instead of interstate for approximately first 500 miles. Now driving between 60 and 80 on interstate for 90 mile round trip to work. A few miles is city.
First few fillups were 24+ mpg. Tonite filled up on way home and mileage is up to 25.43.
I am happy with 25 mpg. I would like to put a topper, probably leer on the truck.
What kind of change in mpg should I expect with a topper ?
wolftree 05-14-2012 06:32 PM
My4X4Tacoma,
A topper will only get you a fractional gain in mileage at best. If you have other needs for a topper, great, but do not spend $1500 for a topper expecting huge gas savings.
Pugga 05-14-2012 06:34 PM
No change or possible slight increase on the highway and slight potential drop in MPG's in the city just due to the added weight that you need to get going off the start. If you get a shell with a roof rack, that could create more drag and affect your highway MPGs. I agree with Wolftree, don't buy a shell just for MPGs.
My4x4Tacoma 05-14-2012 06:36 PM
Originally Posted by wolftree (Post 5088228)
My4X4Tacoma,
I dont expect any gain in gas mileage, but would be very happy if it helped. I really want the topper for the covered space and for the hunting dog.
I am more concerned that the topper might have a negative impact on the gas mileage. But hopefully not much.
wolftree 05-14-2012 07:00 PM
It should make very little difference in milage really. As you are planning on hauling your dog, be sure to get operating windows and vents.
BuzzardsGottaEat 05-14-2012 11:00 PM
It is my understanding that a larger flat rear surface (tailgate+topper) will create more drag than just tailgate (tonneau cover).
The optimal shaped topper for fuel efficiency would slant from the back of the cab gradually down to the top of the tailgate.
Therefore, topper = theoretical loss and tonneau = theoretical gain
However, if you're not going racecar speeds the difference will be negligable. If you lose .3 mpg or something but gain functionality/something you need/a warm spot for the pups there is really no reason not to get one. Just wanted to clarify that everything I've read/researched from ecomodders etc has pointed to a topper equalling a minor theoretical loss.
You can easily counter that with a number of other things
