Noise coming from drivers side Front suspension area (on a 2011...)
Discussion in '4 Cylinder' started by litegide24, Jul 4, 2012.
  1. Jul 4, 2012 at 11:25 AM
    litegide24
    litegide24 [OP] Well-Known Member
  2. Jul 19, 2012 at 4:46 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Steve
    Buffalo NY
    2010 RC 2.7 4x4
    BUCKLE UP! It makes it harder for Aliens to pull you out of your Truck.
    While removing dried wax from the driver side fender (forward and back) I found the clunk I've been hearing,,,,,the fender was LOOSE! I tightened the fender up and it's quiet as a.....Cadillac....or Bentley. [​IMG]
  3. Jul 21, 2012 at 3:51 PM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    Hey liteguide, I've noticed this noise on mine as well ever since the first 2,000 miles or so. I figured it was just a "feature" of the vehicle but now I'm going to investigate.
    edit: http://www.automd.com/tsb/bulletin_b332999/
  4. Jul 21, 2012 at 9:21 PM
    jpaw30
    jpaw30 Well-Known Member
    Im hearing a clicking sound from my drivers side when going slow with the window down.
    Its sound similar to a brake click when they start going bad but Im sure its not the brakes. Any ideas?
  5. Jul 22, 2012 at 9:59 AM
    johnanm
    Up
    You probably have a rock stuck in your tire
  6. Jul 23, 2012 at 1:12 PM
    jpaw30
    yeah I checked it for rocks when I heard it and nothing.
  7. Dec 9, 2013 at 2:30 PM
    Jasonclayf66
    Jasonclayf66 New Member
    Ft Lupton
    2013 Tacoma
    None
    I have also had this same problem with the fuse box cover. I taped it shut and the noise stopped. Dealer said there was nothing they could do. So basically I have to live with a taped up truck.
