-   -   drive shaft noise / bearing noise / dry grinding / on deceleration / 2nd gen 4x4 reg (http://www.tacomaworld.com/forum/4-cylinder/237825-drive-shaft-noise-bearing-noise-dry-grinding-deceleration-2nd-gen-4x4-reg.html)
blatant 09-05-2012 12:53 PM
This topic has been pushed around but the following link is the best i stumbled upon ANYWHERE.
if i find more i'll put them in here. If you have the noise read this, it'll save you some stress. if you have any good links, post them in here for maybe a one stop reference. i know there are a few on tw and tn.
http://www.ttora.com/forum/showthread.php?t=43824
blatant 09-05-2012 06:10 PM
http://www.tacomaworld.com/forum/2nd...on-60-mph.html
http://www.tacomaworld.com/forum/2nd...ma-2007-a.html
http://www.tacomaworld.com/forum/2nd...ay-speeds.html
http://www.toyotanation.com/forum/61...riveshaft.html
Randy63 09-08-2012 05:10 PM
Regular Cab Rattle
I owned a 2009 Regular Cab 4x4 with the manual transmission. I bought the truck in June of 2010 and sold it in August of 2012. My trucks drive shaft/transmission rattled when the truck was on bumpy/unpaved roads when the drive train was unloaded.
I brought the truck to the dealer under warranty. The dealership (Scranton Toyota) really tried to fix the problem. They kept the truck for three days and attached a chassis ear to try to pinpoint the rattle. The best they could do was to replace the drive shaft which didn't help at all. The service adviser told me that Toyota is aware of the issue and it only affects the Regular Cab 4x4s with the manual transmission. They haven't found a fix for it that I'm aware of.
My truck also had the droning noise coming from the drive shaft that is referenced in the threads above. The problem never got any worse over time but it never got any better either.
In addition to the threads above I also found these other threads when looking for a solution for my regular cab rattle.
http://www.toyotanation.com/forum/61...tch-noise.html
http://www.tacomaworld.com/forum/4-c...ttle-back.html
http://www.toyotanation.com/forum/61...ttle-slop.html
http://www.tacomaworld.com/forum/2nd...ps-clutch.html
http://autos.yahoo.com/toyota-truck/...ws/?reviewId=6
Here's a link to Edmunds.com where I reviewed my time with my 2009 Tacoma.
http://www.edmunds.com/toyota/tacoma...wId=1063632197
I hope this thread helps someone down the road.
blatant 10-19-2012 03:28 PM
bump
Fast1 10-23-2012 04:40 PM
I've got 95K on my 06 4x4 and it has made this noise upon deceleration since I've owned it but still has not caused any further problems.
In fact, during my initial test drive of a low milage 06 I heard this noise and did
not purchase the vehicle thinking there was a problem with it. After test driving several more and hearing the identical noise on each at deceleration from high speed, I quit worrying about it.
blatant 03-09-2013 08:36 PM
bump, for the new owners
