-   -   95 taco differential case rusted through. covered by recall? (http://www.tacomaworld.com/forum/4-cylinder/242678-95-taco-differential-case-rusted-through-covered-recall.html)
tunasalad 10-05-2012 06:53 PM
noob here.
I noticed my rear (only) differential case looked a little wet. I took a closer look and it's leaking fluid. Weird, huh?
So, the car is pretty much free of rust except for this one spot on the top of the differential case which seems to be rusted through. The top. Weird.
So, I'm out trying to find a 3.583/3.58 rear axle assembly (rear end).
Does anyone think this would be covered by that rust recall? Probably not, but I figure I'd better check.
Can anyone point me to info on that recall or the rust warranty? Thanks!
shemp 10-10-2012 06:32 AM
The rust warranty extension applies to frame rust through. You're on your own.
tunasalad 10-11-2012 12:26 PM
yeah
yeah that sounds about right. thanks!
