-   -   Reg Cab Lift Vibes/Grinding (http://www.tacomaworld.com/forum/4-cylinder/243617-reg-cab-lift-vibes-grinding.html)
GEORGE STRAIT 10-12-2012 02:32 PM
Obviously the reg cabs are notorious for making this noise when lifted, although after searching through different threads it seems only people with manual transmissions get them. Has anybody had/heard of someone having the grinding/vibration noises that has an automatic?
GEORGE STRAIT 10-14-2012 11:41 AM
Originally Posted by bzzr2 (Post 5829669)
what rear lift do you have? the only grinding i got was after installing dakar leaf packs giving me over 3 inches of rear lift, when i just had a 1 inch rear block no grinding but that was shat.. i flipped my driveshaft to resolve the grinding from that but it is still there, just a lot less after the flip. what i noticed is with no gas in the tank and nothing in the box it is worse, so when the angles are highest under no load. i have 3 degree shims on the rear axle. if your grinding is different please provide more details so ppl can help you pinpoint things..!
Right now I have no rear lift and my billies at 1.75--no grinding, but Im considering doing an AAL and moving up to 2.5, but I've heard lots of stories of people grinding. Just cant decide about the cost/benefit haha
wolfman00 10-14-2012 08:32 PM
mine groans a bit. usually around 40-50mph when i left off the gas. Mine is also an auto.
George, I have the same truck/color/set up as you, except I have a 1" block out back.
