Dipstick Inaccuracy?
Discussion in '4 Cylinder' started by themeat424, Oct 12, 2012.
  1. Oct 12, 2012 at 2:46 PM
    themeat424
    themeat424 [OP] Active Member
    NY
    12 Regular Cab 4x4 Auto
    I changed my oil today, and after reading threads on here about how much oil to replace, I decided to first put in 5.5 quarts. I let the truck sit on level ground for about 40 minutes and then checked the dipstick. It's reading well above the full mark. I checked several times and kept getting the same reading. If I looked harder maybe I saw the oil looking a little "thicker" half way between the low and full markings, but I might just be looking for something. So now I'm wondering what to rely on. Do we just go with the 6 quarts the manual says to add and negate the dipstick? I understand some oil is still sitting in the motor, but exactly how much is that? Kinda confusing...
  2. Oct 12, 2012 at 2:53 PM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    Did you start the truck up after the change to cycle the oil in the filter and passages?
  3. Oct 12, 2012 at 2:58 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    dipstick should be fairly accurate...
    unless you have a dent in the oil pan.
    sample your oil level after you've started/shut down the motor
    thus allowing the old oil to mix with the new.
    btw... the oil level is acceptable...
    as long as it reads between the lower and upper fill lines.
    tho' most folk prefer to be nearer the upper fill line.
  4. Oct 12, 2012 at 3:00 PM
    OffroadToy
    My owners manual says 5.5 qts but that shows up above the full mark on the stick... 5.25 qts puts it spot on.
  5. Oct 12, 2012 at 3:02 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Also depends on how long you let oil drain. Every drop adds up
  6. Oct 12, 2012 at 3:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Run the engine to circulate the oil.
    Shut down.
    Remove the dipstick and wipe.
    Wait 5 minutes.
    Insert and remove the dipstick.
    But it's a gauge... it's not a meter. As said, between the dots is fine, and from the top to bottom dot is about a quart difference.
    On an oil change, just use 5.5 and you're good.
  7. Oct 12, 2012 at 7:07 PM
    OffroadToy
    I let it drain a good half hour...
  8. Oct 13, 2012 at 7:40 PM
    themeat424
    NY
    Yes I started the engine and let it idle for a little. I also drove around before I parked it to sit and then 40 minutes later I checked the dipstick. Unless the oil is being spread on the dipstick while pulling it out, it reads well above the top dot. And yes I do support the stick and hold it horizontally.
  9. Oct 13, 2012 at 8:10 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    some residual oil stays up on the head/valvetrain...
    so you will never be able to drain it completely.
    I'd suspect that you added too much using 5.5 qts
    have fun removing the excess :D
    * I put 5.75 qts in mine with an over sized filter ;)
  10. Oct 13, 2012 at 9:41 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    I just changed mine 3 hours ago. Added 5.5 qts ran it for 5 min and checked. It read well above the second mark, so I let it sit for a bit re-checked it and was spot on. This may be obvious but wipe the dip stick clean and insert, than immediately pull dip stick. If you let the dipstick sit to long you may be allowing residual oil from the tube to get on dip stick.
  11. Oct 13, 2012 at 11:40 PM
    themeat424
    NY
    I actually installed a Fumoto oil drain valve, so removing some oil is actually nothing more than opening the valve for a couple seconds ;)
  12. Oct 14, 2012 at 12:00 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Start the engine, let it run a few minutes. Shut it off, wait 3 minutes. Then check the engine oil. It's ok to have a little extra.
  13. Oct 14, 2012 at 12:28 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    5.5 is fine.
    Gelo likes to put in 6 and he's overfilling it but he'll argue that point all day (as he did in a thread 6 months ago).
  14. Oct 15, 2012 at 5:50 AM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    I wonder, you made no mention of changing the filter. Did a new filter get bought, and still lies on your workbench still in the box? ( member of the OH NO! club )
  15. Oct 15, 2012 at 7:02 AM
    themeat424
    NY
    This is not my first time changing the oil on a car or truck ;) Yes the filter was changed with a purolator pureone, which looks to be the same size as the oem filter.
  16. Oct 15, 2012 at 8:36 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That sounds about right... here's my experience (2006 2.7L):
    6 quarts (w/filter) puts me well above the full mark
    5.5 quarts (w/filter) reads just above the full mark
    5 quarts (w/filter) reads just below the full mark
    Been running it with 5qt and no problems, as expected, since the level is well between the marks. I might go with a little more oil (5.5) during the summer months when increased cooling capacity might help.
  17. Oct 15, 2012 at 4:12 PM
    themeat424
    NY
    Exactly, so now is the dipstick telling the true story on what the oil level should be? or do we just go with the manual that says 6 quarts? Basically, can we confirm that the 6 quarts mentioned in the manual is referring to a completely dry engine, and that when doing a full oil change with filter there is still approximately a half quart sitting in the motor?
  18. Oct 15, 2012 at 4:19 PM
    rhowell
    rhowell Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    The dipstick in the cubicle beside me is not very accurate but that is my problem of the day.............
  19. Oct 15, 2012 at 6:33 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
  20. Oct 15, 2012 at 7:07 PM
    OffroadToy
    I go by the reading on the dip stick.
    The Chilton's manual says the same thing as my owners manual for engine/gear oil capacities except they mention...
    * All capacities approximate. Add as necessary to bring to appropriate level.
