It Was Dark, I Was Tired ... Yadda Yadda Yadda Poured Oil Into Power Steering. HELP!
Discussion in '4 Cylinder' started by ToyOwner, Oct 21, 2012.
  1. Oct 21, 2012 at 12:22 AM
    ToyOwner
    ToyOwner [OP] Member
    Tacoma 4-Banger 4X4
    So the internets say that everything is fabulous; I just have flush the power steering. And the internets say that everything is terrible and that I'm going to destroy my rack and pinion ...
    I haven't started the engine, and managed to get a good deal of it out with a turkey baster. It's in a grocery store parking lot, so I'm hoping I can do whatever I need to do with it right there.
    It's a Tacoma 4X4 four banger, 2.7 I believe, if that helps at all.
    Any advice appreciated (and yes, you can laugh, it's okay)!
  2. Oct 21, 2012 at 12:31 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    might be able to pull the lines off the rack and point them in a buck to drain the rest. if not, I don't see it doing any harm. at least you didn't pour it in the radiator...
  3. Oct 21, 2012 at 12:31 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    fawk...
  4. Oct 21, 2012 at 6:59 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    My 03 Tacoma manual calls for Dexron II or III for the steering system (hydraulic system).
    We used to run motor oil (10W40) or hydraulic oil or Dexron III as hydraulic fluids in railroad roadway equipment hydraulic systems for tie & rail installation. Sometimes we would mix different fluids when changing oil, without issues.
    Like Btnewman, I don't see any harm either.
  5. Oct 21, 2012 at 7:01 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    Good luck. That's pretty Krazie....
  6. Oct 21, 2012 at 7:03 AM
    Large
    Large Red
    I see what you did there
  7. Oct 21, 2012 at 7:15 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
  8. Oct 21, 2012 at 7:17 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    I'd say drain what you can and fill it with power steering fluid. Run it a couple days then drain it again and refill it. Should be fine
  9. Oct 21, 2012 at 7:18 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK First - don't panic.
    Second, yeah you're gonna want to flush it and put in the right fluid.
    And flushing it is a bit of a messy job.
    So really, if it was me? I'd just drive it to the nearest 'oil quick change lube' type joint and have them flush it for me. They're set up with tubes and exchangers to do fluid flushes as neatly as possible. Whereas if you DIY this particular job, you're gonna end up with more spilled fluid under the hood.
    Now if a quick oil place wasn't close by, I might use a big syringe or gear oil pump to remove the fluid out of the reservoir, then refill it with actual power steering fluid before I drove over there for a complete flush.
    But as self inflicted hassles go, this is fairly small time. Do take care of it right way, but don't worry, be happy. :)
  10. Oct 21, 2012 at 7:43 AM
    jjew18
    jjew18 the Nightman cometh!
    John
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Waiting for hilarity to ensue!
  11. Oct 21, 2012 at 7:55 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Both are the correct answer. You choose the solution.
  12. Oct 21, 2012 at 7:55 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    No one has asked why he was changing his oil in a grocery store parking lot?
  13. Oct 21, 2012 at 7:59 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Sodiam Vapor overhead lights? :anonymous:
  14. Oct 21, 2012 at 8:27 AM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's pretty obvious, no oil change involved, - just late at night, low on oil, go into the store, buy two quarts, come back out, flip open the lid (they're within what, six inches of each other?) start pouring.... GAAAK!!!:eek:
    And the lesson to be learned? Don't let your truck get so low on oil in the first place that you need to add oil under those circumstances.
  15. Oct 21, 2012 at 8:29 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I'm here to supervise.
  16. Oct 21, 2012 at 8:35 AM
    Delmarva
    Tucson, AZ
    oh good! :D
  17. Oct 21, 2012 at 11:20 AM
    ToyOwner
    Tacoma 4-Banger 4X4
    Thanks, all!
    Yeah, that. And THIS: Never become so comfortable with doing something that you don't even bother to think about it anymore. I'd added oil a thousand times without incident. It was as familiar as taking a whiz. What could POSSIBLY go wrong? ;)
  18. Oct 21, 2012 at 7:04 PM
    ToyOwner
    Tacoma 4-Banger 4X4
    Okay, so, I siphoned the fluid out, and, refilled it with ATM, and given what was said here, I'm going to drive it to a quick lube to get it flushed out tomorrow.
    Right? Does anyone want to scare the hell out of me so I can agonize over this a little more? Last chance!
    THANKS!
  19. Oct 21, 2012 at 7:18 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    if you are really sweating about damaging it, have it towed.
  20. Oct 21, 2012 at 7:48 PM
    bjmoose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Boo. Happy Halloween. :frankensteinsmonster:
