K and n air intake?
Discussion in '4 Cylinder' started by Bmeadow1, Dec 26, 2012.
  1. Dec 26, 2012 at 8:51 PM
    Bmeadow1
    Bmeadow1 [OP] Active Member
    Brogan
    Concord, NC
    2013 prerunner
    Maglites, camo seats
    So my question would is it a good idea to put a K and N air intake on my 4 cyl?
    And would I actually see any results in any places?
  2. Dec 26, 2012 at 9:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No and no.
    More dirt, more hassle, more cost.
    OEM filter is $15, needs replacing once every year or two, filters better than anything, and can flow more air than even the V6 can pull.
  3. Dec 26, 2012 at 9:25 PM
    Bmeadow1
    Brogan
    Concord, NC
    2013 prerunner
    Well it would be of an on road only daily driver truck
  4. Dec 26, 2012 at 9:30 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    afe drop in filter :D
  5. Dec 26, 2012 at 9:33 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Usage doesn't matter.
    Even more important if you take it off road at all, but the K&N and other "washable" filters do not filter well and allow fine particles through that will score the cylinders and lead to increased oil consumption.
    Another problem with the oiled filters is if they are not properly oiled, they will foul the MAF, leading to poor running, check engine light, and poor gas mileage.
    The drop-in filter is around $55. You can buy 3 stock filters for that... and then you have to buy the cleaning/recharge kit for another $20.
    $75 for the filter and kit, or enough OEM filters to carry you 150,000 to 300,000 miles (change interval is 60k, inspect at 30k).
    And there is ZERO benefit to running the K&N or similar drop-in on a stock vehicle.
  6. Dec 26, 2012 at 9:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Better than K&N, but if you gave me one, I'd sell it on eBay and donate the money to charity.
  7. Dec 26, 2012 at 9:43 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    If your looking for more engine sound and a little more HP then yes.
    My honest opinion is that it was kind of a waste of $ for me to buy the K&N FIPK intake. If I could somehow put on a regular throw-away cone air filter then I'd do that because I actually do like the intake tube.
  8. Dec 26, 2012 at 10:07 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    why is that?
  9. Dec 26, 2012 at 10:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    OEM filters better and flows more than the engine can possibly use unless you have a supercharger.
    The tradeoff for having an aftermarket filter is all negative. There is no benefit unless you count "BRAAAP"
  10. Dec 26, 2012 at 10:23 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    ive had zero problems with my afe
  11. Jan 7, 2013 at 11:23 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    i removed the secondary filter in my 09,changed to a k&n drop-in,and got 0 mileage increase.not 1 tiny bit.so a cold air kit is probably money down the drain.
  12. Jan 8, 2013 at 9:40 AM
    phsycle
    phsycle Well-Known Member
    CA
    When I ran a K&N, I sent the oil in for analysis and the silicone levels had spiked way up. They said it is usually the cause of dirt/grime and other contaminents getting into the engine. The only thing not stock was the K&N filter. So I changed it back to paper filters and all is well again. I won't use K&N or other aftermarket filters again.
  13. Jan 8, 2013 at 4:24 PM
    Soccerdallin
    Soccerdallin Well-Known Member
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Magnaflow exhaust w/ tip, 18" Rockstars, AEM CAI, TB Spacer, Billet Grille, Limo tint, LED tail lights, 20,000k HID headlights + Blue LED strips, debadged, Jl Audio Subs in custom box, 6X8 speakers with tweeters, sony deck.
    I had K&N and they tend to make Tacoma's engine lights go off because it covers the MAF with so much crap. You will feel an increase in power, but K&N's are high maintenance because of the cleaning. I got an AEM Brute Force now since it requires no oil and maybe just have to take a hose to it every year or two and that's it.
    You will get more power tho.
  14. Jan 8, 2013 at 8:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I've been preaching that for years brother, but nobody cares, because racetruck.
  15. Jan 9, 2013 at 7:16 PM
    Bmeadow1
    Brogan
    Concord, NC
    2013 prerunner
    Ok so unfortunately my parents got me one already for Christmas and now after reading all of the posts I'm not sure what I should do with it now????
  16. Jan 9, 2013 at 7:22 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    drop in filter? I had one worked well (ie no problems I noticed) until I went to recharge it (not first time I recharged one) and apparently I must have poured it on.. no clue but I did too much and soaked my charcoal filter and messed up MAF sensor.. so needless to say I removed it.. It worked wonders in my ford and chevy I had but my taco didn't like it at all...
  17. Jan 9, 2013 at 7:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The hp difference with the 2.7 engine, with the OEM filter vs. NO filter at all is about 1. One hp. So, unless the new filter/intake is going to presurise the intake system, you will gain nothing.
  18. Jan 9, 2013 at 7:25 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    my recommendation would be use it ..until you have an issue since you have it.. just be very careful with recharging it... if anything let it sit hanging for a few days after you do it just incase...
  19. Jan 9, 2013 at 8:29 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I like my K&N fipk... (don't like K&N's drop in element)
    not really caring what the haters do or think
    I used the original element for 12 years.
    have never purchased another filter element for my junk during that time.
    the original element developed a little dry rot (avoidable).
    so I asked K&N for a replacement and they shipped that NCTM
    so their lifetime warranty works great.
    as well... I still have my oem AB/fuzzy w DP mod.
    is sometimes installed when I know I'll be rolling wetter trails.
    otherwise the fipk resides most always.
    I've saved some money over the years
    by not needing to purchase replacement filters.
    I'd ruin a stock filter (oem AB) in just a weekend
    is a 4X that gets used off road often
    btw, paid $ 120. for my fipk back in the day.
  20. Jan 9, 2013 at 11:41 PM
    Soccerdallin
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    If you check out my build you can see the difference between the K&N FIPK and the AEM Bruteforce. Get the Bruteforce and you won't be disappointed. I loved the K&N, just didn't like how it set my engine light off every few months.. :/
