alignment issue
Discussion in '4 Cylinder' started by Mr.Schertz, Dec 31, 2012.
  1. Dec 31, 2012 at 10:29 PM
    Mr.Schertz
    Mr.Schertz [OP] Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    Im adding the fat bobs 2.75 and AAL. Im also gonna get the bilstien HD stuts for up front. I plan on keeping the stock rims but whats the biggest tire i can put on without having alignment issues?
  2. Dec 31, 2012 at 10:43 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    I got 265's on my truck and no problem
  3. Dec 31, 2012 at 10:57 PM
    Mr.Schertz
    TEXAS
    I should mention I have a 5 lug (15in rims), and want to know if I will need to have it aligned after the lift and tires?
  4. Dec 31, 2012 at 11:00 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
  5. Jan 1, 2013 at 6:46 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    What he said.
    With the lift you can go up to a 31 inch tire. Most people then put on new wheels that are a little wider so they can accommodate the extra width of 31x10.5x15 or 245/75/16 size tires. I think the largest tire you can put on the stock 5 lug rims is 30x9.5x15 or 235/75/15. The limiting factor on the stock rims is that they are only 6.5 inches wide. If you go up to 7 or 8 inches wide then 31" tire sizes will fit.
  6. Jan 20, 2013 at 4:10 PM
    WhiskeyTango
    WhiskeyTango New Member
    Kyle
    All over the US
    '12 Tacoma 4 cyl
    i have stock suspension and just put 235/75/15 stock rims on my baby with no problems, i used BFG T/A KO and i absolutely love them, check them out when you upgrade
