Poor fuel economy
Discussion in '4 Cylinder' started by Silver Streak, Jan 8, 2013.
  1. Jan 8, 2013 at 5:01 PM
    Silver Streak
    Silver Streak [OP] Well-Known Member
    Westin Bull Bar
    My 2011 tacoma with the 2.7L has had a pretty drastic drop in fuel economy lately. I know in the winter its common to have somewhat of a drop due to colder weather. But my fuel economy has gone from about 21 mpg to almost 17 mpg average. nearly 5 miles per gallon. That seems like a bit much and has me wondering if i have something wrong with my truck. Anybodey else notice this or have any problems like this?
  2. Jan 8, 2013 at 5:04 PM
    RelentlessFab
    Eric
    Sparks, NV
    Mine went from 18-19 down to 14-15 lately. Its all about the winter gas and cold weather leading to long warm-ups
  3. Jan 8, 2013 at 5:10 PM
    Silver Streak
    Westin Bull Bar
    well thats reassuring at least. definatley noticed that it has the longer warm ups, ideling higher for longer.
  4. Jan 8, 2013 at 5:10 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Wonder if the colder, more dense air is also dragging the mpg's down (more friction), in addition to the longer warm-up times.
  5. Jan 8, 2013 at 5:17 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    i got 265/75-15's with a level kit.i'm 19 no matter what
  6. Jan 8, 2013 at 5:29 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    I feel your pain. My v6 tacoma was averaging 18-19 last spring when i bought it new. The last few tank have been 14-15. IMO This is horrible, so much so that im thinking about selling it to buy a dodge diesel with 25mpg. This makes me sad :(
  7. Jan 8, 2013 at 5:41 PM
    Silver Streak
    Westin Bull Bar
    Makes me want to sell my truck too. but im hoping my fuel economy bounces back when spring rolls around
  8. Jan 8, 2013 at 5:49 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Cooler air and winter blend fuel eats into mpg
  9. Jan 9, 2013 at 5:53 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Colder air is more densely packed with oxygen molecules, and since the engine draws a fixed volume of air, there is more oxygen available for burning when its colder. The A/F ratio needs to be maintained for a proper burn to take place, so the ECU raises the amount of fuel injected into the mixture in order to compensate for the extra oxygen in colder air. This produces a bigger bang, but at the cost of efficiency.
  10. Jan 9, 2013 at 6:13 AM
    ecoterragaia
    Central Virginia
  11. Jan 9, 2013 at 6:15 AM
    ecoterragaia
    Central Virginia
    Sorry for the double post, dont know what happened there . . .
  12. Jan 9, 2013 at 8:52 AM
    phsycle
    phsycle Well-Known Member
    CA
    In addition to what has been said, most states run at least 10% ethanol in winter, which in my experience caused about a 10% drop in MPG. Another small factor is that dense air is harder to push through, causing even more drop in MPG (albeit not that much). This is like going from Aspen CO (5k ft) to New Orleans (at or below sea level). More power, but worse MPG.
  13. Jan 9, 2013 at 10:02 AM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Depending on the price of the new truck and diesel it will not be worth it. I work for Dodge I've seen tons of people trade in for a diesel just for fuel mileage. If you need a diesel then go for it. Let me know if you need any parts.
    Oh and what Ram gets 25mpg. The 5.9L 2wd were lucky to be getting around 20 21. The 6.7L pssst. Keep in mind too if your buying new that our diesels take around 60-100k to break in to be getting better gas mileage too.
  14. Jan 9, 2013 at 10:34 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your brakes for signs they are dragging, lube your driveshaft, make sure your tires are properly inflated, and make sure your trans, engine, diff, xfer-case fluids are all up to date. Make sure there is no water in the diffs as well.
  15. Jan 9, 2013 at 10:35 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Check air filter, and run through some Seafoam too.
  16. Jan 9, 2013 at 2:15 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Back in October I was getting close to 25mpg but my latest tank was barely over 21. *Nothing* has changed except the weather and the fuel blend.
  17. Jan 9, 2013 at 6:35 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    colder weather, longer idles, and winter gas. Mine has also
  18. Jan 9, 2013 at 7:52 PM
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    I've gone from 20-21 on every tank with boring consistency to between 16 and 20. My wife was driving it a lot during the crazy snow we had (her focus couldn't get out of the driveway for a while) and I blame her ;)
    For me though, I think it is what everyone has said: longer idle times, takes longer to warm up, maybe more time in 4wd with snow/ice, winter blend gas, etc. I also just switched from 245/75r16 tires to 265/75s so it is hard for me to pinpoint a culprit. However, since taking back my truck full time from the wife and watching the fuel gauge, I think I will be back up to 20 mpg this tank..
  19. Jan 9, 2013 at 8:57 PM
    tacowagon
    tacowagon Well-Known Member
    Portland, Or
    2011 SR5 4x4 Access Cab
    Toytec/Eibach springs, Bilstein 5100 shocks, Light Racing UCA, AFE ProDry, Softopper
    Since buying my truck a month ago, I was thinking the same thing. I've only ran a few tanks through the truck and average about 16mpg. I thought it was the truck, but after reading this thread, I'm glad I'm not the only one. We're getting closer to spring....
    specs: 11 4wd sr5, 2.7L, 20k miles, afe pro dry drop in filter, secondary filter mod, and stock tires.
  20. Jan 9, 2013 at 8:58 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    i'm a 4.0L but I went from 21mpg to 19.5mpg ....
