-   -   Poor fuel economy (http://www.tacomaworld.com/forum/4-cylinder/257160-poor-fuel-economy.html)
Silver Streak 01-08-2013 06:01 PM
Poor fuel economy
My 2011 tacoma with the 2.7L has had a pretty drastic drop in fuel economy lately. I know in the winter its common to have somewhat of a drop due to colder weather. But my fuel economy has gone from about 21 mpg to almost 17 mpg average. nearly 5 miles per gallon. That seems like a bit much and has me wondering if i have something wrong with my truck. Anybodey else notice this or have any problems like this?
RelentlessTaco 01-08-2013 06:04 PM
Mine went from 18-19 down to 14-15 lately. Its all about the winter gas and cold weather leading to long warm-ups
Silver Streak 01-08-2013 06:10 PM
well thats reassuring at least. definatley noticed that it has the longer warm ups, ideling higher for longer.
T Fades 01-08-2013 06:10 PM
Wonder if the colder, more dense air is also dragging the mpg's down (more friction), in addition to the longer warm-up times.
texascolt45 01-08-2013 06:17 PM
i got 265/75-15's with a level kit.i'm 19 no matter what
RDtres 01-08-2013 06:29 PM
I feel your pain. My v6 tacoma was averaging 18-19 last spring when i bought it new. The last few tank have been 14-15. IMO This is horrible, so much so that im thinking about selling it to buy a dodge diesel with 25mpg. This makes me sad :(
Silver Streak 01-08-2013 06:41 PM
Makes me want to sell my truck too. but im hoping my fuel economy bounces back when spring rolls around
ziggynagy 01-08-2013 06:49 PM
Cooler air and winter blend fuel eats into mpg
ecoterragaia 01-09-2013 06:53 AM
Colder air is more densely packed with oxygen molecules, and since the engine draws a fixed volume of air, there is more oxygen available for burning when its colder. The A/F ratio needs to be maintained for a proper burn to take place, so the ECU raises the amount of fuel injected into the mixture in order to compensate for the extra oxygen in colder air. This produces a bigger bang, but at the cost of efficiency.
ecoterragaia 01-09-2013 07:13 AM
ecoterragaia 01-09-2013 07:15 AM
Sorry for the double post, dont know what happened there . . .
phsycle 01-09-2013 09:52 AM
In addition to what has been said, most states run at least 10% ethanol in winter, which in my experience caused about a 10% drop in MPG. Another small factor is that dense air is harder to push through, causing even more drop in MPG (albeit not that much). This is like going from Aspen CO (5k ft) to New Orleans (at or below sea level). More power, but worse MPG.
whahahajr 01-09-2013 11:02 AM
Depending on the price of the new truck and diesel it will not be worth it. I work for Dodge I've seen tons of people trade in for a diesel just for fuel mileage. If you need a diesel then go for it. Let me know if you need any parts.
Oh and what Ram gets 25mpg. The 5.9L 2wd were lucky to be getting around 20 21. The 6.7L pssst. Keep in mind too if your buying new that our diesels take around 60-100k to break in to be getting better gas mileage too.
skytower 01-09-2013 11:34 AM
Check your brakes for signs they are dragging, lube your driveshaft, make sure your tires are properly inflated, and make sure your trans, engine, diff, xfer-case fluids are all up to date. Make sure there is no water in the diffs as well.
skytower 01-09-2013 11:35 AM
Check air filter, and run through some Seafoam too.
DGXR 01-09-2013 03:15 PM
Back in October I was getting close to 25mpg but my latest tank was barely over 21. *Nothing* has changed except the weather and the fuel blend.
maxpower29 01-09-2013 07:35 PM
colder weather, longer idles, and winter gas. Mine has also
adrstout 01-09-2013 08:52 PM
I've gone from 20-21 on every tank with boring consistency to between 16 and 20. My wife was driving it a lot during the crazy snow we had (her focus couldn't get out of the driveway for a while) and I blame her ;)
For me though, I think it is what everyone has said: longer idle times, takes longer to warm up, maybe more time in 4wd with snow/ice, winter blend gas, etc. I also just switched from 245/75r16 tires to 265/75s so it is hard for me to pinpoint a culprit. However, since taking back my truck full time from the wife and watching the fuel gauge, I think I will be back up to 20 mpg this tank..
tacowagon 01-09-2013 09:57 PM
Since buying my truck a month ago, I was thinking the same thing. I've only ran a few tanks through the truck and average about 16mpg. I thought it was the truck, but after reading this thread, I'm glad I'm not the only one. We're getting closer to spring....
specs: 11 4wd sr5, 2.7L, 20k miles, afe pro dry drop in filter, secondary filter mod, and stock tires.
jeffvt0508 01-09-2013 09:58 PM
i'm a 4.0L but I went from 21mpg to 19.5mpg ....
