-   -   2013 2.7 what did they change engine wise? (http://www.tacomaworld.com/forum/4-cylinder/259036-2013-2-7-what-did-they-change-engine-wise.html)
TwzteD 01-19-2013 09:10 PM
I have a 2013 2.7 and i have this weird tick wich sounds like an exhaust leak, but it only happens at idle when the truck is warmed up at or close to operating temp(very seldom i hear it wile accelerating). I am wondering about what they changed from 2010 to 2013.. i know they put in the air pump for emmisions but what else if anything. I had a 2010 with 35k and it didnt make this noise ever, i can hear it inside the cab at stoplights and what not. Mabey its the injectors? but it don't do it all the time and my 2010 was not nearly as loud. Anyone with a 2012 or 13 have this issue?
Here's a video
http://i3.photobucket.com/albums/y74...C417931F52.mp4
S
ecoterragaia 01-21-2013 07:20 AM
My 2006 RC ticks at idle especially when cold, always attributed it to the injectors. And BTW, the air pump isnt a new feature, it has always been included with the 2TR engine.
TwzteD 01-21-2013 07:24 AM
My 2010 didn't have one :/
Here's of vid of ticking
Shooting Bull 01-21-2013 07:25 AM
I have a 2012 with a 2.7, no tick.
TwzteD 01-21-2013 07:27 AM
Does yours sound like the vid?
TwzteD 01-21-2013 08:52 AM
Anyone with a newer 2.7 tell me if this sounds normal?
SocoandLime 01-21-2013 02:50 PM
2012 Manual with 6500 miles. Never had a tick
Gelo760 01-21-2013 02:52 PM
Don't hear a tick in either of my 2.7's . A knock sometimes . Even this year backfires are way down .
TwzteD 01-21-2013 03:29 PM
Noones answering my question does the vid sound normal or som ting wong
Lazylegs 01-21-2013 03:32 PM
Sounds normal for the toyota motors. I don't hear a tick, just the air being moved around by the belts.
sr5vic 01-21-2013 07:30 PM
2013 2.7 @ 900km; no ticks.
That Dude Tim 01-21-2013 07:36 PM
Doesn't really sound normal, but if it's new why not try and have the dealer look into it. One thing that can make noise on the V-6 is a air switching valve that bolts to the intake with one bolt on the drivers side of the engine. Probably not your issue but was the source of my ticking on my truck, just removed the bolt and let it hang by the rubber hose.
trooper12 01-22-2013 05:31 AM
I have a 2012 2.7 and it sounds exactly like yours. It ticks quietly and you can only hear it with the hood open. I don't think that it did that new though...
TwzteD 01-22-2013 05:40 AM
I can hear mine in the cab though maby they forgot to sound proof or something just seems to be louder than my 2010 2.7 I just hope I didn't get a dud
Mattnatti 01-22-2013 05:58 AM
Yeah, my 12' doesn't sound like that. At least not yet. I have almost 13k on the clock.
How many miles on yours?
TwzteD 01-22-2013 12:47 PM
1700 miles
ecoterragaia 01-22-2013 08:38 PM
Just got a chance to listen to your video, it sounds like mine but maybe a little louder. Though it's hard to tell if it's louder because the mic is right next to the engine.
Mine is much louder in the winter than the summer. Whenever I get in close it really sounds like the injectors and the EVAP purge valve. I always hypothesized that it's because the injectors are working harder to deliver more fuel due to the cold air.
TwzteD 01-23-2013 03:48 AM
You may be right man I just got this truck few weeks ago and it never seen warm weather yet, maby I just never noticed it on my last truck cause the trans was so much more clumky and loud than the engine , I mean it doesn't sound like metal or valves so I'm sure there's nothing to worry about. Maby it will be quieter in the summer, about to do the first oil change at like 2000 miles for the hell of it. I will see if that's makes any difference from outside the truck it sounds like a tick from inside a slight exhaust leak but it only happens when the truck is warm and at idle, so like if I come to a stop light i don't hear it for like 5 seconds after I stop the it starts, so maby it's the injectors or something working harder... Idk
Robnik 01-23-2013 04:22 AM
Mine sounds exactly the same as yours. I'm sure it's normal. I even have the same vertical "mark" on the oil filler neck & cap.
TwzteD 01-23-2013 05:27 AM
I parked next to a co workers 2010 2.7 this mornin and mine is def louder Maby they put diff injectors in that are louder or something not really sure I know these engines are bulletproof as a guy on here has over 400k on his 05 2.7.
