Removing Head
Discussion in '4 Cylinder' started by dually, Feb 6, 2009.
  1. Feb 6, 2009 at 6:51 PM
    dually
    dually [OP] Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Well I'm undertaking a big project next week: Remove the head. I have a 1.5mm Cometic headgasket and ARP headstuds coming next week. Any tips on keeping the timing? Any things I should watch out for? I dont think this should be too bad, just a little time consuming. I think I might as well swap out my oil pan while im at it too!:D I'll be sure to get pics and what not!
  2. Feb 6, 2009 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Should be pretty straight forward. Disconect the battery so if someone "accidentally" turns the key, the starter wont engage and screw anything up. There are marks on the cam sprockets and crank so you can line everything up.
  3. Feb 6, 2009 at 7:08 PM
    dually
    Yeh, I had the valve cover off this week to take a peak and check my valve clearances. They were DAMN TIGHT! Might just get the head rebuilt while im at it... Thanks!
  4. Feb 6, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    get it ported, and you'll pick up some extra ponys. ;) Shouldnt be much more.
  5. Feb 6, 2009 at 7:10 PM
    dually
    Would it be a bad idea to maybe just "polish" the exhaust ports myself? I know there is a bit of science when it comes to porting.
  6. Feb 6, 2009 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cant hurt, but your not gonna gain too much.
  7. Feb 6, 2009 at 7:14 PM
    dually
    Yeh, I wouldnt expect that much. Im hoping the 15psi of turbocharged air will fill the void!
  8. Feb 6, 2009 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im sure it will do just fine. :D
    Are you going to decompress?
  9. Feb 6, 2009 at 7:17 PM
    dually
    The 1.5mm gasket should lower compression a little bit. Considering Luis@Paradise Racing said that a 1mm gasket would work fine for 15lbs
  10. Feb 6, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nice. I cant wiat to hear how it runs! :D
  11. Feb 6, 2009 at 7:20 PM
    dually
    Its going to be a process for sure! Still have to find suitable 440cc injectors and wire up my Emanage. The tuning is going to be the longest and most time consuming step in the boosting process!
  12. Feb 7, 2009 at 5:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Why 440 injectors? Seems a bit much, any concern for propper atomization of the fuel?
  13. Feb 7, 2009 at 6:46 AM
    dually
    Stock are about 320cc, I would be maxing the duty cycle out @15psi. Most guys with the same plan as me have gone up to 550cc.
  14. Feb 7, 2009 at 7:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah.....I thought stock for that engine were around 280 or so. :eek:
  15. Feb 7, 2009 at 8:07 AM
    dually
    Actually, it may be... Im not sure, I was just told that the 440cc would be the largest to fit in the stock injector rail. So thats what im going to go with, might was well go big all at once!
  16. Feb 7, 2009 at 11:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hell, yeah! :)
  17. Feb 9, 2009 at 8:26 PM
    dually
    Here is as far as i got after 2.5hrs of work:
    My hands have never been so cut up before!!!
  18. Feb 10, 2009 at 6:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not too bad for 2.5 hours. Wear some gloves!!! :)
  19. Feb 10, 2009 at 12:36 PM
    dually
    Ehh, I dont like the feel of the gloves, or lack there of! I should be able to get it done by tonight.. hopefully! Turbo is going on this week too!!!
  20. Feb 10, 2009 at 1:07 PM
    mjp2
    Milton Juevo Portimous II
    NJ
