2TR-FE MAF Sensor & Throttle Body Cleaning
Discussion in '4 Cylinder' started by 05Taco4x4, Feb 10, 2013.
After cleaning, do you notice any different engine behavior on a cold start?
  1. NO
    35 vote(s)
    42.7%
  2. Yes, I see a rise in initial RPM
    17 vote(s)
    20.7%
  3. Yes, I see a fall in initial RPM
    6 vote(s)
    7.3%
  4. Yes, I see erratic RPM behavior
    1 vote(s)
    1.2%
  5. Yes, No, What? I was hoping to seee bewbs
    23 vote(s)
    28.0%
  1. Feb 10, 2013 at 7:48 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Tools:
    10mm Socket
    Ratchet
    3" extension
    Long Nose Pliers
    #1 Phillips
    Toothbrush
    Rag
    Good Practice:
    Torque Wrench (covers 36-80 in. lb.)
    Ohmmeter
    Hazmat:
    Mass Air Flow Sensor Cleaner
    Throttle Body Cleaner
    Disconnect Negative Battery Terminal (36 in. lb.)
    Disconnect the MAF wire harness, then remove the two #1 Phillips screws.
    Pull the MAF Sensor straight up and out.
    Spray the wires
    DO NOT TOUCH SENSOR
    Reverse process to reassemble.
    Throttle with Motor Body Assembly
    Remove the Resonator Bolts (3) (71 in. lb.)
    Loosen the Hose Clamp, both sides of Resonator (44 in. lb.)
    Disconnect the Vacuum Hose
    Disconnect the No. 2 Ventilation Hose
    Disconnect the Pressure Sensor Connector​
    Lift the Resonator and Hose Assembly up and forward, exposing the Throttle Body Assembly.
    Disconnect the Throttle Motor Connector.
    Remove the Bolts (2) and Nuts (2) (80 in. lb.)
    Disconnect the Water By-Pass Hoses (2).
    Lift Throttle Body Assembly stright up, exposing the Intake Manifold.
    Note: There is a non-reusable rubber gasket between the Throttle Body Assembly and the Intake Manifold (I reused mine).
    Bottom view, before cleaning.
    Bottom view, after cleaning.
    Clean with Throttle Body Cleaner, following directions on back.
    t1m829, AgentCovert, po35042 and 4 others like this.
  2. Feb 10, 2013 at 11:19 PM
    EricTheRed
    EricTheRed Damn dirty Swede
    Eric Sven
    Kelowna, BC
    Five lugs of might and fury
    BHLM, General Grabber A/T2 235/75R15 on stockers, Magnaflow 11225, Tonneau cover, Pop 'n Lock, Lots of dog hair...
    Bravo! Thank you sir...I appreciate having clear directions like this.
  3. Feb 11, 2013 at 12:58 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Nice work.
    Grab a bottle of sea foam and run it through the intake as well. Typically hooked up to the vacuum line off the brake booster, it's sucks the SF through the vacuum line and cleans out the air chamber.
  4. Feb 12, 2013 at 6:14 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Nice write up, thanks a lot for the info.
  5. Feb 15, 2013 at 2:38 PM
    alwaysfaded
    alwaysfaded Well-Known Member
    Adam
    So. Cal.
    08 Black taco, 5 spd.
    blacked out tint, k&n drop in, removed secondary filter, kenwood 7" touchscreen, 12" memphis audio sub, 1000 watt amp, Alpine type R conponets
    Awesome job, was looking for exactly this.
  6. Feb 24, 2013 at 9:16 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    did you notice any diffrence in performance or Mpg's after doing this
  7. Feb 26, 2013 at 3:20 PM
    05Taco4x4
    2TR-FE Enthusiast
    Yes - I deleted my secondary air filter at the same time, and the battery was disconnected long enough to reset the ecu. This is the reason I posted the poll, so everyone could see what to expect as time goes on
  8. Jan 20, 2014 at 1:18 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks for the write up and pics. ImpulseRed008 posted the link for me in the 6 forum. There are tons of write ups and Sticky's for 6's but only 2 in the 4 cylinder forum. I'm going to ask a mod to make this a Sticky in the 4 cylinder forum. Thanks again for your work on this.
    Kmier and 05Taco4x4[OP] like this.
  9. Jan 20, 2014 at 1:57 PM
    george3
    New Jersey
    This is now a Sticky so it will be very easy for all us 2.7 4 Cylinder owners to be able to easily take advantage of your write up. Thanks to mod chris4x4 for making it happen.
    05Taco4x4[OP] likes this.
  10. Jul 26, 2014 at 6:32 AM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Does anyone know if the throttle body gasket is a part that can only be bought through toyota? I checked my local auto parts store yesterday and they didn't have any part numbers or anything. I know OP says you may not need one, but it would be my luck to damage the old one.
  11. Jul 29, 2014 at 5:43 PM
    drogers0031
    drogers0031 Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Avid Offroad Light Bar, Yellow OEM fog lights in bumper pockets, Leer 100XR Topper, 4 Leaf pack in rear, Bilstein 5100's on all four corners, Body debadged with front emblem and tailgate emblem rebadged in flat black.
  12. Sep 12, 2014 at 11:01 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    2 weeks ago I did the MAF and throttle body cleaning, and a spark plug change (105000 miles). Cold start RPMs were around 1500 before, now they are 2100 after. Also looks like a noticeable drop in MPGs -- used to hit 80 miles on a full tank before the gas gauge came down to the F mark, today it only had 55 miles at the F mark. Will have to do the calculation to see the truth but it doesn't look good. Doesn't run any smoother either but it always ran smooth, even before the MAF and throttle body cleaning and new plugs.
  13. Sep 12, 2014 at 2:43 PM
    george3
    New Jersey
    All that work and drop in MPGs :eek::eek:. That shouldn't be - let us know if it gets better when the computer has time to relearn. Thanks.
  14. Sep 13, 2014 at 10:47 AM
    DGXR
    Friend
    Sacramento, CA
    Will do.
    A couple things I forgot to add:
    1) I did disconnect the battery for several hours during the service so that the computer can re-learn based on information from the clean MAF.
    2) After doing the service, I did my routine workday driving for a week and then took a road trip to the coast. The average over 635 miles was 25.4 MPG, which is generally "good," but this road trip was about 70% highway -- keep in mind that my routine workday driving is 50% highway (with more frequent cold starts than a road trip), with an overall average of 24 MPG prior to the service.
    The cold start RPMs do seem to be coming down very slowly over time and I am hopeful that they will eventually mellow out at the 1600-1700 range. But I will give an update later, maybe in a month, unless a sudden change happens and then I will post sooner.
  15. Sep 13, 2014 at 10:53 AM
    george3
    New Jersey
    This is very interesting. Thanks for your reply and update. Looking forward to your post in a month or two. I wonder how much time the relearn usually takes for us 2.7's :confused:
  16. Sep 17, 2014 at 10:29 PM
    DGXR
    Friend
    Sacramento, CA
    Looks like my speculation about the lower MPGs may have been wrong, although it was easy to make this mistake when the full mark showed about 55 miles, which is very strange, the truck has never done that before.
    My routine driving (before MAF and TB cleaning, and new plugs) yielded 24.3mpg and looked like this:
    Full mark = 80 miles
    3/4 mark = 140 miles
    1/2 mark = 240 miles
    1/4 mark = 340 miles
    It was amazingly consistent too, "like clockwork" as they say.
    My current tank was at ~252 miles today when the 1/2 mark passed, so now it looks much better than anticipated and I'm a little excited. Cold start RPMs are still too high but still coming down very slowly. Will post another update after filling up next week.
  17. Sep 22, 2014 at 10:24 AM
    DGXR
    Friend
    Sacramento, CA
    Filled up this morning: 24.6 MPG on this last tank of routine driving.
    Didn't drive the truck at all this weekend and today's cold startup hit 2500 RPM.
  18. Oct 21, 2014 at 3:15 PM
    DGXR
    Friend
    Sacramento, CA
    OK this is going to be my last update (in this thread):
    Last tank was 25.3 MPG and still purrs like a kitten, very pleased.
    However...
    Cold start RPMs are rising back up a tiny bit as the winter overnight temps keep dropping... any given day, cold start may be anywhere in the 2200-2500 RPM range. I'm not worried about anything breaking or wearing out prematurely... the higher cold RPMs are for a quick warmup of the cats (to qualify as a LEV) but it is quite annoying.
  19. Mar 31, 2015 at 2:17 PM
    LIRR
    LIRR Member
    Brian
    Pa
    02 SR5 Taco w/alts
    I'm running a 2002 2.7 taco, 4x4, new plugs, did the MAF cleaning with a battery disconnect. Still getting 13 MPG??? I plan on doing a Throttle Body cleaning this week (if the damn snow will ever let up), changed the plugs too. Am I missing something? I've got a code for the Idle Air Control Motor. Does that need to be cleaned or replaced?
  20. Apr 12, 2015 at 8:43 PM
    tacoma4
    tacoma4 Well-Known Member
    How much coolant did you lose when you took the throttle body off?
