-   -   still having problems with my idle (http://www.tacomaworld.com/forum/4-cylinder/268666-still-having-problems-my-idle.html)
jrbauserman 03-17-2013 11:25 AM
Ok so my 97 2.7L with 277,000 mi. idles high. I took off the throttle body and cleaned it including removing the IAC which did not look bad. The ilde is about 300-400RPMS high. the coolant level is good but I was thinking about replacing the temp sensor anyway the part is much cheaper than an IAC valve. When I had the throttle body off there was a large amount of carbon just inside the intake where there is a port to the EGR valve. I cleaned that out also with no change in idle. anyone have any suggestions? I really do not want to throw a $160 IAC valve at if im only guessig. If I know that will fix it I have no problem doing it.
Rackster 03-17-2013 11:48 AM
Was this something that was gradual or literally on the next startup?
Tacoyota 03-17-2013 07:34 PM
Sticky throttle cable or misadjusted cable stop maybe.
Also I had a ford stuck in closed loop cycle or such, had to get some egr stuff fixed too, you might need to do more there.
