-   -   4 cylinder power (http://www.tacomaworld.com/forum/4-cylinder/268677-4-cylinder-power.html)
Big Bear dude 03-17-2013 01:34 PM
4 cylinder power
Hi I'm a new member and considering the purchase of a 4 cylinder 4x4 standard or access cab. My concern is that living in the mountains I have to climb up and down frequently and that the power will be an issue. I'm an electrician and carry mostly hand tools and a ladder but I'm climbing 4000' on a 16% grade at times.
Secondly how will it do in the snow?
MightyMouse-SCT 03-17-2013 01:41 PM
Get the stick and it will most likely need a regear .
Big Bear dude 03-17-2013 01:52 PM
Regear ?
Tacoyota 03-17-2013 08:20 PM
My manual does fine going skiing/hiking in Oregon or Washington, no 16%s though, holds speed on grades at say 50mph, but wont accelerate on them over 4-5k altitude. As far as snow, it'll do as well as any other truck, but I always use winter tires. Power will be an issue, its a 4 cylinder, but it does damn good for one.
oldblue1968chevy 03-17-2013 08:23 PM
Theres about a 1/2 mile hill pretty steep grade, I can pull it @ 3500rpm's @ 70mph in my 4cyl auto, granted that's pretty windin it out for the lil Toyota though.
MightyMouse-SCT 03-17-2013 08:24 PM
Originally Posted by Big Bear dude (Post 6602651)
Regear ?
Lower gears to help . If you don't mod it ( bigger tires , lift ) it should probably be ok .
Tacoyota 03-17-2013 08:26 PM
On freeways, it holds speed any grade/speed for me, but mountain grades and altitude start to challenge any engine, especially smaller ones for a given model.
pigger 03-18-2013 12:04 PM
I live above 5000 feet, and my 2.7L reg cab is not fast by any means, but it goes up hills OK if I'm in the appropriate gear. At this altitude, I have to shift down for the steeper hills, especially if I've got weight in the bed.
jmlinne 03-18-2013 03:11 PM
My 2.7L 5-speed handles hills and snow just great. Now that It has 170,000 and low compression I don't try hills in 5th but in 4th I have no problems. The 4wd is excellent in snow and ice. In and out of 4H with a flick of the wrist. In Montana we all use studded snow tires for the ice.
DGXR 03-18-2013 05:19 PM
Did you check your compression? How do you know it's low? 170k is not that many miles for a modern Toyota 4-cylinder.
Billyj870m9 03-19-2013 06:37 AM
Honestly if I lived in hilly areas I would have traded my 4 banger already. For where I live it's ok but I have a feeling you'll need a little more power for all the hills.
That being said I love mine for what I do. I don't tow and don't haul a lot besides my self and work stuff. I will prolly be getting a v6 soon just because I want a dclb and it only comes in the sport in my area.
newertoy 03-19-2013 06:51 AM
6 cyl is better for steeper and longer grades--had a 4cyl-did OK.
BUT 6 cyl is MUCH BETTER-have the 6cyl now. spend the extra $$$ you will not regret it.
jmlinne 03-19-2013 04:03 PM
Yes I did a differential pressure compression test like we do on aviation engines. It registered an average near 40/80 psi if you understand the meaning. This test also helps identify the source of leaks and mine are primarily rings.
Juggernaut 03-19-2013 04:07 PM
I have the 4 cyl and live at sea level. When I took it skiing I was surprised how much power it lost. If i lived above 5000 ft elevation I would not have bought my 4cyl.
On the plus side once you get used to it and you bring it back down the hill it is as if someone dropped a supercharge in it, so much more power!
BuzzardsGottaEat 03-19-2013 04:14 PM
What power?
Tacoyota 03-19-2013 04:44 PM
[QUOTE=newertoy;6611579]6 cyl is better for steeper and longer grades--had a 4cyl-did OK.
BUT 6 cyl is MUCH BETTER-have the 6cyl now. spend the extra $$$ you will not regret it.[/QUOTE
Drove one, better acceleration, but only does the exact 75mph as a 4 cyl. My 4 cyl is paid and I don't regret it . I don't regret the 25-26 mpg either , I don't regret the lower maintenance. 6cylinder is nice , nothing against it , but a lot of us just either don't need or want it.:)
BuzzardsGottaEat 03-19-2013 04:59 PM
25-26 in a 5 lug, no problem, in a 4x4, thats a stretch . . . not saying you're lying, just impressed at such FE with 4x4.
Tacoyota 03-19-2013 05:10 PM
65 mph speed limit in Oregon, as opposed to 75 elsewhere, its highway mpg too still on stock tires too, fuel efficient , but not great off road. Its not too hard to do with some small efforts.
EatMyTacomaDust 03-19-2013 09:26 PM
^^^^ Excellent Answer
Test drive both and you'll probably get your answer. But if you get the 2.7L - Get a stick.
bjmoose 03-19-2013 09:34 PM
Nobody will mistake the 2.7 banger for a speed demon. That said, it has plenty of power for everyday driving use - even on hills, as long as you're willing to use the gearbox.
I'm lifted and running on oversized tires, carrying a fair amount of armor and tools, and even still on the Barstow to Bakersfield climb yesterday (into a heckuva headwind) I could always hold 70 or 75 on the climbs - unless I had to slow down for other traffic.
But only you know how much power you really need. So I advise you test drive both for a lengthy test drive.
