best lift
Discussion in '4 Cylinder' started by cadle09, Apr 17, 2013.
  1. Apr 17, 2013 at 1:10 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    08 single cab tacoma
    None yet, reason I joined gotta lurn more before I add the wrong stuff
    So many lifts. Im new to all this and wanna lift my 08 single cab tacoma, manual 4banger. I would like to clear 33s without any scraping or rubbing I wont be off-road much so would like to keep the ride as good as possible.would really Appreciate some feedback and experience.
  2. Apr 17, 2013 at 1:12 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Spacers! with a add a leaf. 175$
  3. Apr 17, 2013 at 2:12 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    What brands are best? And I like the clearance you have can I get that with a 3"
  4. Apr 17, 2013 at 3:42 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea mine is a 3" and I love it. It's a procomp/ez lift brand.
  5. Apr 17, 2013 at 3:46 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Toytec sells good kits, old man emu by ARB is very popular here. Spacers aren't your best option. Most cases you will need to do some modifications/triming to prevent 33" tires from rubbing even with a 3" lift
  6. Apr 17, 2013 at 3:55 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Ok thanks guys makes things harder when eceryone likes different lifts and brands. So if I went 4 I would prob be fine? And there's just so many lifts toytecs coilover with 5100s but eceryone says dont do coil lift or and I dont care for a body lift
  7. Apr 17, 2013 at 3:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    "best" is subjective. it all comes down to how much you want to spend
    everyone says to stay away from spacers, not coils
  8. Apr 17, 2013 at 4:10 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Idc about price really I got nothin but time to save just as long as its right. But in my head I had 2000 lol but no spacers got that now are coil, 5100s all around and add leaf a good idea?
  9. Apr 17, 2013 at 4:16 PM
    lovemytaco
    lovemytaco Active Member
    Dana
    Savannah, Ga
    I just installed the ome lift on my truck from toytec and I love it I'm running 285/65r18 and only had to trim a little bit of my fender liner. I'm very happy with the lift so far I do not off road my truck tho I have another truck for all that.
    5571F6FA-2686-45B5-8574-A47FB8B46A41-453_59c25840a27b1fa78d3cd17542624d9f2199f60d.jpg
  10. Apr 17, 2013 at 4:17 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    You 2wd or 4x4?
    If 2wd get lift spindles. If 4x4 expect a rough ride to get the height you want with the truck you have, not much weight there.
  11. Apr 17, 2013 at 4:17 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    5100s with AAL is a good plan, one step better would be to use aftermarket coils. You can also upgrade to a full leaf pack instead of a AAL. New upper control arms are also a good upgrade. You said if i went 4 i would prob be fine, do you mean 4" of lift? That would leave you with very little downtravel and wouldnt be a good idea. Anything over 3" would be a drop bracket lift
  12. Apr 17, 2013 at 4:31 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Ok so, 5100s, full leaf pack, coils and upper control arm. Is what ill do now last question lol coils whish should I go with?
  13. Apr 17, 2013 at 4:35 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Lol, now your at $1500-$2000 bucks. You might not need all the things i listed. If your really interested in going with "the best" get some high end coilovers like icons or fox's. as far as coils with 5100s you can get old man emu 884s or 885s. 885s alone will probably give you about 3" of lift, or you can go with eibach coils.
  14. Apr 17, 2013 at 4:49 PM
    caseychai
    caseychai Well-Known Member
    casey
    oahu
    2010 tacoma 4x4
    what im in the process of doing to my 2010 access cab is the 5100s all around with ome 885 coils and 2 inch AAL in the rear with 285/75/16 tires, sits right at 3 and minor trimming for no scraping. if you have just single cab you would probably still get the 3 inches with the 884s or even eibach coils. good luck!
  15. Apr 17, 2013 at 4:53 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  16. Apr 17, 2013 at 5:05 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Or spend 200$ on a lift and the rest on wheels and tires :)
  17. Apr 17, 2013 at 5:27 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Ok thanks for all the knowledge. I think I have what I need and I do like randys build. Thanks everyone
  18. Apr 17, 2013 at 5:28 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    bilstein 5100's 300 - 330 set fr and rear
    ebiach coils 190.00
    icon 3 leaf pack 200
    lr uca 375
  19. Apr 17, 2013 at 7:19 PM
    cadle09
    cadle09 [OP] Member
    jake
    ohio
    Would a coilover be better than a coil and 5100s?
  20. Apr 17, 2013 at 7:23 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yes
