-   -   best lift (http://www.tacomaworld.com/forum/4-cylinder/273659-best-lift.html)
cadle09 04-17-2013 01:10 PM
best lift
So many lifts. Im new to all this and wanna lift my 08 single cab tacoma, manual 4banger. I would like to clear 33s without any scraping or rubbing I wont be off-road much so would like to keep the ride as good as possible.would really Appreciate some feedback and experience.
Millertime187 04-17-2013 01:12 PM
Spacers! with a add a leaf. 175$
cadle09 04-17-2013 02:12 PM
What brands are best? And I like the clearance you have can I get that with a 3"
Millertime187 04-17-2013 03:42 PM
Yea mine is a 3" and I love it. It's a procomp/ez lift brand.
evanmb31 04-17-2013 03:46 PM
Toytec sells good kits, old man emu by ARB is very popular here. Spacers aren't your best option. Most cases you will need to do some modifications/triming to prevent 33" tires from rubbing even with a 3" lift
cadle09 04-17-2013 03:55 PM
Ok thanks guys makes things harder when eceryone likes different lifts and brands. So if I went 4 I would prob be fine? And there's just so many lifts toytecs coilover with 5100s but eceryone says dont do coil lift or and I dont care for a body lift
Konaborne 04-17-2013 03:56 PM
"best" is subjective. it all comes down to how much you want to spend
everyone says to stay away from spacers, not coils
cadle09 04-17-2013 04:10 PM
Idc about price really I got nothin but time to save just as long as its right. But in my head I had 2000 lol but no spacers got that now are coil, 5100s all around and add leaf a good idea?
lovemytaco 04-17-2013 04:16 PM
I just installed the ome lift on my truck from toytec and I love it I'm running 285/65r18 and only had to trim a little bit of my fender liner. I'm very happy with the lift so far I do not off road my truck tho I have another truck for all that.
http://i107.photobucket.com/albums/m...psba70dd49.jpg
Mr Salty 04-17-2013 04:17 PM
You 2wd or 4x4?
If 2wd get lift spindles. If 4x4 expect a rough ride to get the height you want with the truck you have, not much weight there.
evanmb31 04-17-2013 04:17 PM
5100s with AAL is a good plan, one step better would be to use aftermarket coils. You can also upgrade to a full leaf pack instead of a AAL. New upper control arms are also a good upgrade. You said if i went 4 i would prob be fine, do you mean 4" of lift? That would leave you with very little downtravel and wouldnt be a good idea. Anything over 3" would be a drop bracket lift
cadle09 04-17-2013 04:31 PM
Ok so, 5100s, full leaf pack, coils and upper control arm. Is what ill do now last question lol coils whish should I go with?
evanmb31 04-17-2013 04:35 PM
Lol, now your at $1500-$2000 bucks. You might not need all the things i listed. If your really interested in going with "the best" get some high end coilovers like icons or fox's. as far as coils with 5100s you can get old man emu 884s or 885s. 885s alone will probably give you about 3" of lift, or you can go with eibach coils.
caseychai 04-17-2013 04:49 PM
what im in the process of doing to my 2010 access cab is the 5100s all around with ome 885 coils and 2 inch AAL in the rear with 285/75/16 tires, sits right at 3 and minor trimming for no scraping. if you have just single cab you would probably still get the 3 inches with the 884s or even eibach coils. good luck!
evanmb31 04-17-2013 04:53 PM
Check out randys build here
http://www.tacomaworld.com/forum/2nd...ion-build.html
Similar to your truck, im sure he will give you some pointers also
Millertime187 04-17-2013 05:05 PM
best lift
Or spend 200$ on a lift and the rest on wheels and tires :)
cadle09 04-17-2013 05:27 PM
Ok thanks for all the knowledge. I think I have what I need and I do like randys build. Thanks everyone
BORNWILDGUY 04-17-2013 05:28 PM
bilstein 5100's 300 - 330 set fr and rear
ebiach coils 190.00
icon 3 leaf pack 200
lr uca 375
cadle09 04-17-2013 07:19 PM
Would a coilover be better than a coil and 5100s?
Millertime187 04-17-2013 07:23 PM
Yes
