-   -   Cylinder #1 misfire (http://www.tacomaworld.com/forum/4-cylinder/277659-cylinder-1-misfire.html)
sdssk8 05-13-2013 04:27 PM
Cylinder #1 misfire
This may be a dumb question but which one is the #1 cylinder on an 01 4cyl, closer to the front of the car or towards the driver
BamaToy1997 05-13-2013 06:44 PM
The front cylinder is the #1.
TACO TX 05-13-2013 06:53 PM
Sparkplug!
goldstar 05-16-2013 05:52 AM
just changed my plugs and still have a misfire ...Duh... HELP...PLEASE
sdssk8 05-16-2013 03:57 PM
So I replaced the spark plugs about 2 months before this misfire problem began, I looked at the plug it seems fine and I replaced the coil. Still have the misfire, I want to replace the wires but I'm not sure how to go about it, is it just a harness on each end or is it a pain in the ass to do. Any suggestions
Taylor 05-16-2013 04:39 PM
Are you sure it's not a batch of bad gas?
JHG57 06-03-2013 10:51 AM
Mine did that years ago, it was a pinhole in the plug-wire allowing the voltage to bleed off.
gcoates 06-03-2013 02:54 PM
Try using ETHONOL FREE GAS - had the same problem,,,,,,,,,seems the ethoh in the gas draws water into your engine. Put ethonol free gas in my truck and now it dose not spit or sputter like before............ I was surprised.......... go on puregas.org to find closest place that sells this gas.
