-   -   22re weak or normal ? (http://www.tacomaworld.com/forum/4-cylinder/277883-22re-weak-normal.html)
halogene 05-14-2013 06:33 PM
i am wondering if my 22re in a 89 toy pickup (Xtracab) 186 000 Km not miles is weak or it is made like this. under 2700 rpm on the 2 speed ..(sorry my bad english guys.) it is so weak it take like 20 secs to go up in rpm on a small hill really small hill like 5 degree angle hill. compared to my toy celica Gt 1.8 .. i looked at the specs 22re 98hp if i remember well and vvti 1.8 is 142. there is a huge difference on de pedal is that normal ? i never had a 22re re befaure this is my first toy pickup. if you need know more information ask it. i had in mind that probably O2 sensor was fucked up or something ? thanks you!
halogene 05-15-2013 12:34 PM
note: i have 31 inch tire offset
tooter 05-20-2013 03:50 AM
Is 31 inches larger than the stock tire diameter? If it is, then the higher gear ratio is helping to make your truck sluggish. My 2012 truck came with big heavy 245/75/16 tires. When I went back to the stock diameter 235/60/16 tires, it really perked up. :)
I used to have a 1988 longbed and loved its simplicity and utility. :)
halogene 05-21-2013 05:25 PM
yeah i may not help i think there was 28 inches tire stock they are larger and bigger i should compare with a other 22re pickup
