Short throw shifter?
Discussion in '4 Cylinder' started by jluyk, Oct 24, 2013.
  1. Oct 24, 2013 at 11:17 AM
    jluyk
    jluyk [OP] Well-Known Member
    Justin
    Lake George, NY
    2013 2.7L 4x4 Access 5-Speed
    Toyo Open Country AT2s 245/75R16
    Anybody know if there's a short throw kit for those of us with 5 speeds? Why should the 6 speeds have all the fun?
  2. Oct 24, 2013 at 11:19 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    google core shifters hes got one:D
    contact the guy he seems to be out atm not on his website atm
  3. Oct 24, 2013 at 4:27 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I chopped off my lever on my 5 speed,
    and that also shortened the throw. ;)
  4. Oct 24, 2013 at 5:16 PM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    URD makes a short throw kit for our 2.7L 5 speed trans
    make sure you click the correct one there is one for 2.7 PRE 2005 and one for 2.7 2005- current
    I believe it goes for $110
    im looking at picking it up for my 4 banger
  5. Oct 24, 2013 at 5:18 PM
    jluyk
    Justin
    Lake George, NY
    I like the length/height of the stock shifter but the throw from 1st to 2nd is just too long!! :mad:
  6. Oct 26, 2013 at 12:09 PM
    Taco 22
    Taco 22 Active Member
    I was thinking of getting one of these from URD. It looks like they are on sale right now. The short-throw shifter doesn't actually change the height/length of the shifter, it changes the pivot point resulting in less travel when changing gears.
  7. Oct 27, 2013 at 3:06 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    URD. I have one. Works great, no problems.
  8. Oct 27, 2013 at 3:18 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    URD for sure. Also Coupe makes custom shifters, chops it and fills it, thats what i want. Not cheap but im sure it is probably the best option for us in tandem with the URD.
  9. Nov 5, 2013 at 9:01 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Can vouch for the URD as well - works great though it does heighten the stick about half and inch or so.
  10. Nov 12, 2013 at 6:26 PM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    Just installed the URD in my 2010 2.7. Very simple install. Worst part was getting the shifter to trans bolts in and out. Clean way is to take to take a small grinding wheel and notch it out. I just grabbed some channel locks and bent the metal out enough that I could wiggle them in. After torqueing the new shifter to trans bolts I just bent the metal back into shape. Other than that worst part was emptying my center console :D.
    As far as driving it feels like I just traded in a model T for a Ferrari. That is all you need to know, and the big URD sticker is gonna gain me at least 50hp :bananadance::bananadance::bananadance:
    Thanks to the folks at URD for a great product!
  11. Nov 13, 2013 at 7:05 AM
    Tunngavik
    Alberta, Canada
    I got a 52 HP increase and 5 mpg more too! :kona::kona::kona:
  12. Nov 22, 2013 at 10:51 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    Ok this is dumb and might get called names but what is a short throw shifter? What is the up side and down side of this?
  13. Nov 23, 2013 at 7:01 AM
    Timberland Taco
    Berlin, NJ
    2013 V6 6-speed 4x4
    A short throw shifter decreases the distance between the up and down gears. Basically when you go to shift you don't have to pull the shifter as far to reach the next gear. Many people consider these tacomas to shift like a dump truck, so this helps with less time on the clutch, and it doesn't feel as much like your rowing a boat going through the gears.
  14. Nov 23, 2013 at 7:08 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I have a URD one and my height is stock, works great. Sometimes third is hard to get in but thats every now and then
  15. Nov 23, 2013 at 11:00 AM
    tooter
    Greg
    Los Angeles
    When the throw is shortened, you automatically lose a little mechanical leverage over the shifting forks.
  16. Nov 23, 2013 at 7:29 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I figured it was that and not my truck ha
  17. Nov 23, 2013 at 8:40 PM
    tooter
    Greg
    Los Angeles
    My chopped lever is similar as I also lost a little leverage with the shorter length. It just makes the shifter a little bit more "notchy", and not a problem. I really like the shorter lever and shorter throws... feels more like a sports car. ;)
    Greg
  18. Nov 23, 2013 at 10:44 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Whats up with the do dads in the ciggarrette lighter ports. Is the one on the left a volt meter?
    I think the tacoma shifter is pretty nice for a truck. I had a 5 speed jeep comanche with a
    Pretty long throw, but it did go into gear real easy, I figured it was just wore out. Even the jeep though wasn't bad compared to the old granny 4 speeds in full size trucks.
  19. Nov 23, 2013 at 11:06 PM
    tooter
    Greg
    Los Angeles
    Yes, it's a nifty little volt meter that I got off ebay for just $3 including free shipping. The other one is a rechargeable LED flashlight that glows blue when its charging, and when you turn it on the light is white. I got it for $5 from Home Depot.
    Greg
