Who does your brake job?
Discussion in '4 Cylinder' started by bboynowee, Mar 16, 2010.
  1. Mar 16, 2010 at 9:06 AM
    bboynowee
    bboynowee [OP] Well-Known Member
    Riverside
    17 TRD 4x4 Tacoma OR, 18 4Runner TRD, 18 TRD 4Runner
    Stage 4 Icon, Icon Rebound Wheels, DeMello Hybrid Sliders, Prinsu roof rack
    Just wondering... who does your brake job....My taco is due for a brake job and not sure if to take it to a mechanic or change them myself.:rolleyes:
  2. Mar 16, 2010 at 9:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    I do my own.
  3. Mar 16, 2010 at 9:11 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  4. Mar 16, 2010 at 9:12 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    do it yourself. it is easy, as long as you pay attention (and assuming you have the proper tools). do one side at a time, and put everything back in the reverse order you took it off.
    and it will save you big $$$$$
  5. Mar 16, 2010 at 9:16 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i do everything myself! :cool:
  6. Mar 16, 2010 at 9:18 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Always do it myself. Nobody else is going to take the proper time and care to make sure the job is done right.
  7. Mar 16, 2010 at 9:22 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Do it yourself. Brake pads are easy, especially on this truck. If you're bleeding brakes to change fluid for the first time get a buddy (or forum member) thats done it before. Brake bleeds are easier with two people anyway.
    The only thing I'd consider taking the truck in for is those dumbass drum brakes. I've never changed a set, but then again I'll never learn if I don't do it.
  8. Mar 16, 2010 at 9:26 AM
    pwrstrk02
    pwrstrk02 Well-Known Member
    randy
    kansas city missouri
    2010 4x4,dc,off road, black pearl
    i think brakes scare mid to older aged people more so than younger. when they used to be drum brakes you had all the springs, adjusters, rust and hammers, a whole can of W-D 40, not actualy knowing if you needed new hubs. with disc brakes, its just two bolts to get the calliper off, mabey a screwdriver to pry the piston back in, and a set of mic's to measure the rotors. its too easy, just do it. i look at it this way. the hardest part is starting, once you start you have to finish, just dont be stupid about it.
  9. Mar 16, 2010 at 9:39 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    don't pry the pistons back in with a screw driver. get yourself a big c clamp and before taking off the pads, press the pad/piston back in, then remove pad and put on new ones.
    i do mine and hte gf's. dealer qouted 375 to do her fronts. with pads and new discs, i had 120 into the job.
  10. Mar 16, 2010 at 9:40 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I use a big pair of channel locks.
  11. Mar 16, 2010 at 9:41 AM
    81shark
    i believe in my method....i don't want to gouge up the piston or the cyclander. but if yours work.....
  12. Mar 16, 2010 at 9:45 AM
    bigburrito
    DuPage County
    '09 TRD OR
    +1 for the big c-clamp
  13. Mar 16, 2010 at 9:46 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Me and only me!
  14. Mar 16, 2010 at 9:47 AM
    pwrstrk02
    randy
    ok so its not advised to use a screwdriver, thats why i say dont be stupid about it. pry them open with the old brake pads in. if the pistons are fighting you to go back in their hole you are going to scratch things just as much, if not more, with channel locks.
  15. Mar 16, 2010 at 5:45 PM
    Taco.Tim
    Taco.Tim Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    Do my own. Pretty simple.
    Tim Glover
  16. Mar 16, 2010 at 8:55 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    Disc brakes are pretty easy. Pull the wheels, remove the calipers, use either a big c-clamp or a giant pair of channel locks WITH AN OLD PAD to push the pistons back in. Take the cap off the resevoir first, makes things a little easier. You should take the rotors somewhere to have them machined, either an auto parts store or some local shops might do it (for a fee). Drums are a little more complicated. Alway do one side at a time so you can see how it's set-up.
    If you're not comfortable with any of it or you don't have the right tools, try to find a good independent shop. Dealer will charge more (typically). Whatever you do, DO NOT take it to a Meineke or Midas or any other chain repair store for that matter. You get what you pay for and $99 per axle gets you crappy parts installed by Billy the highschool greaser.
  17. Mar 16, 2010 at 8:58 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    i do my own
  18. Mar 16, 2010 at 10:20 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    ive done a couple...not on this truck yet. but its much simpler than the shops charge u for....just do it yourself!
  19. Mar 16, 2010 at 10:20 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    drums on the other hand ill just take it in cause im WAAAAAY to lazy lol
  20. Mar 16, 2010 at 10:42 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
