4Running Daily's 96 4Runner Build
Go Back   Tacoma World Forums > Tacoma Garage > Builds > 4Runner Builds
Taco76087's 1988 4runner Build
Old 01-05-2012, 03:31 PM   #41
First Class White Trash
achirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shed
achirdo's Avatar
achirdo's Tacoma Gallery
Just an SAS...NBD or anything
Old 01-05-2012, 04:54 PM   #42
Taco76087 [OP] Taco76087 is offline
Taco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shed
Taco76087's Avatar
Taco76087's Tacoma Gallery
Seen one seen em all right?
Old 01-05-2012, 05:53 PM   #43
Trying to Spread Common Sense and Rational Thought
tx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shedtx_shooter is one of the sharper tools in the shed
tx_shooter's Avatar
Marines: 1st Fast Co, Golf 2/4
Name: Zech (pronounced zak)
tx_shooter's Tacoma Gallery
Says the guy still drooling over a locker...
Old 01-05-2012, 06:02 PM   #44
achirdo's Avatar
Locker>SAS
Lmao
Old 01-05-2012, 06:06 PM   #45
Taco76087's Avatar
Locker>SAS
Lmao
Old 02-26-2012, 07:19 PM   #46
Glamour Shot
ajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shed
ajohnson's Avatar
ajohnson's Tacoma Gallery
Can you tell me about the front and rear suspension setups on that black runner?
Old 02-26-2012, 08:32 PM   #47
Taco76087's Avatar
It's got ~3" springs in the front with 8" shackles
And 4" springs in the back with 6" shackles
Old 08-05-2012, 03:41 PM   #48
Taco76087's Avatar
Need to update this:
I've added 4.7 transfer case gears
Sliders
63" Chevy springs in the rear
Trail gear low profile front bumper
Working on:
Dual cases
RUF (rear springs up front) building the packs right now.
Maybe some 4:88 gears doubt it though.
Old 08-05-2012, 03:49 PM   #49
tx_shooter's Avatar
You went with the Chebbys?
Old 08-05-2012, 03:51 PM   #50
Taco76087's Avatar
Yeah I got them for $10 for the pair
Old 08-05-2012, 03:58 PM   #51
tx_shooter's Avatar
I guess that makes sense. I need to get to the junkyard and pick up some F-150s pretty quick. I'm going to hunt for the 2 1/2" leafs so as to not have to do a lot of extra work mounting them and they are supposed to be more flexible.
Did you do anything for your drive shaft?
Old 08-05-2012, 04:23 PM   #52
Taco76087's Avatar
Not yet see what it does then go from there. That same place we got my dads springs from is the place to go for sure.
Old 08-05-2012, 04:28 PM   #53
tx_shooter's Avatar
Yeah, I probably see if you want to go over there some time towards the end of the month. I'll buy lunch.
Old 09-16-2012, 10:17 AM   #54
Taco76087's Avatar
Some Updates
Before the 63'' springs
I installed 63'' Chevy springs in the rear and swapped the longer shackles I had in the front to the rear and moved those up front flexes nicely now
Old 09-16-2012, 10:18 AM   #55
Taco76087's Avatar
The ride height is so much nicer now, lower center of gravity
Old 11-19-2012, 04:51 PM   #56
Taco76087's Avatar
Picked up an E-locker for the front just need gears.
Old 11-19-2012, 04:56 PM   #57
Glamour Shot
ajohnson's Avatar
Still wanting 4:88 gears?
Old 11-19-2012, 05:26 PM   #58
Taco76087's Avatar
Looking at 4:88 but may just stick with 4:10 for $$ sake.
Went out to a huge offroad park this past weekend and while it did great, a locker for the front would have made it 100 times easier. The only thing was my ground clearance of some of the large rock faces, I crushed the gas tank skid pretty good. Looking into building one out of plate, and making my own diff armor.
Old 11-19-2012, 05:39 PM   #59
tx_shooter's Avatar
You could just use the steering wheel to move the diffs away from the rocks....
Old 11-19-2012, 05:42 PM   #60
Taco76087's Avatar
Taco76087's 2004 Prerunner TRD Build Taco76087 1st Gen. Builds 102 06-04-2014 08:40 AM
1988 toyota 4runner fs. Matic Buy / Sell / Trade 18 04-05-2013 02:54 AM
1988 Samurai Build... "SUSIE" 01GREENTACO Other Builds 7 05-31-2011 08:19 PM
FOR SALE: 1988 Toyota 4Runner SR5 Ziggy24 Buy / Sell / Trade 15 10-28-2010 01:11 PM
FINALLY Starting my build - 1988 Toyota Pickup 3.0 eagleswarrior 1st Gen. Tacomas 67 03-11-2010 09:04 AM
