SCRunner12's 4Runner Limited
Go Back   Tacoma World Forums > Tacoma Discussion > 4Runners
99 won't start
Old 04-11-2012, 05:59 PM   #1
Yep
buzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shed
buzzard1992's Avatar
buzzard1992's Tacoma Gallery
99 won't start
My sister has a 99 4runner and just called and said it won't start. The past couple weeks it's turns over longer than it should before it cranks. I'm headin to go see what's goin on now. Any help would be great
Old 04-11-2012, 06:18 PM   #2
Yep
Anyone?
Old 04-12-2012, 03:50 PM   #3
hashemg has a spectacular aura abouthashemg has a spectacular aura about
hashemg's Avatar
hashemg's Tacoma Gallery
Starter, Batter, MAF Sensor, Fuel Pump. you got any more info?
Old 04-20-2012, 09:46 AM   #4
I'm dropping the hammer
Bawlzdeep is just really niceBawlzdeep is just really niceBawlzdeep is just really niceBawlzdeep is just really nice
Bawlzdeep's Avatar
Air Force: Chair Force
Bawlzdeep's Tacoma Gallery
If it's been turning over a lot before it starts it's probably the fuel pump. As long as the battery is good and it's turning over fast enough. The pumps get weak and this is how they go out. You're NOT gonna hear this pump prime like almost every other car in the world. It doesn't get power until the starting circuit is closed. The pump is right under the rear driver's side seat. They're kind of expensive too.
Good luck. More info would help.
Old 04-23-2012, 05:09 PM   #6
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Your choice of words here is a bit confusing. 'turns over' and 'cranks' sometimes mean different things to different people.
When the starter motor engages the flywheel causing the motor to rotate, this is what I call 'cranking'. Then it cranks until the motor fires up. Are you saying that there is a delay from when she turns the key and the starter cranks the motor? If so, then this is a problem with the starter.
If the starter 'cranks' for a long time, but the motor never fires up, then you have a fuel or ignition or electrical problem.
Won't start (again)! Cobra6 2nd Gen. Tacomas 6 12-19-2010 04:08 PM
Truck Won't Start db2 2nd Gen. Tacomas 4 11-19-2010 09:14 AM
Won't start - Cobra6 2nd Gen. Tacomas 13 10-22-2010 11:32 AM
won't start ?!? colinb17 General Automotive 3 12-06-2009 08:12 PM
My truck won't start! slammedtaco Technical Chat 16 08-21-2008 01:06 PM
