SCRunner12's 4Runner Limited
Go Back   Tacoma World Forums > Tacoma Discussion > 4Runners
1995 Toyota 4Runner Problems...Need advice!
Old 05-14-2013, 10:09 AM   #1
Jay238 [OP] Jay238 is offline
aka Frank Gallagher...
Jay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shedJay238 is one of the sharper tools in the shed
Jay238's Avatar
Law Enforcement:
Jay238's Tacoma Gallery
Hey guys, my younger brother (17) just bought his first car, a 1995 4runner. Paid for it all on his own, which I am stoked. BUT, it is a DOG. Yes, I have read all over t4r, ttora, and pirate 4x4 about how slow the 3.0 is. But, he can have it floored, pedal to the metal, over-drive off, and the "ECT" power on, going 20 mph up a semi-inclined hill. Engine is all stock and he has a flowmaster muffler, no tail piping. Just muffler which is louder than sin.
Any tips to try quickly at first? I might go ahead and help him out by paying for a regear. His 4runner has some kind of lift, like a drop bracket, with 31" tires. He has the auto trans as well. He bought it at sea level in the Bay Area, and then took it to my fathers house at about 3k elevation. He, and my father, say it ran 100000x at the sea level. Any help will be greatly appreciated. I'm out the in field a lot for work so I couldnt attend the purchase..
PS. I know this is a slowww engine but I feel it shouldnt be this bad. Something is wrong.
Old 05-14-2013, 04:25 PM   #2
4runner Troll
SCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shed
SCRunner12's Avatar
SCRunner12's Tacoma Gallery
Typical maintenance items will help a bit, but unfortunately that engine is weak. A lift and aggressive tires will suck the power out of it. Don't get a regear, but rather look for a junkyard 2nd gen 4runner with factory 4.88's. They are somewhat common and I think the doorjamb code is g144 or something like that. I'd assume he has either 4.56 or 4.30's in there now. Also the auto transmission and 3.0 make a horrible duo. I had the same 4runner and no matter what it was a dog, especially on hills and elevation.
Best bet is to learn to deal with it or drop a 3.4 in there. I chose to do neither, but upgrade to a 3rd gen 4runner.
Old 05-14-2013, 04:28 PM   #3
The Dank Tank
Blacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shed
Blacktacoma23's Tacoma Gallery
Old 05-14-2013, 05:55 PM   #4
Jay238's Avatar
Law Enforcement:
Hmm okay thanks guys
Old 05-16-2013, 10:20 PM   #5
Mad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shedMad Man Marty is one of the sharper tools in the shed
Mad Man Marty's Tacoma Gallery
A dog
Does it drive really slow, or do u think something is wrong?
I had one of these, but it wasnt too bad.
Plugs, wires, coil?
This engine had a head gasket problem. How is your compression?
Is there any anti-freeze leaking?do u have to add?
How about the cat convertor? A partially cloged cat really robs power.
Old 05-17-2013, 01:44 PM   #6
4Runner hooligan
Kevin B. is on a distinguished road
Kevin B.'s Avatar
Kevin B.'s Tacoma Gallery
Is it an auto? The chain drive transfer case behind the a340 series transmissions is a horrible power sucker, but I rolled 31s with stock gearing on my last automatic and it was bad, but not horrible. And that was a 22re, and it was 2000 feet higher than you are .
Are you sure you're not exaggerating how bad it is? If it really can't accelerate up a mild hill, then that's not just gears, something is wrong. I'd start with a complete tuneup and go from there.
Old 05-17-2013, 01:59 PM   #7
Jay238's Avatar
Law Enforcement:
On a mild hill, it cant go past 20mph..
Old 05-18-2013, 02:30 AM   #8
4Runner hooligan
Kevin B.'s Avatar
Something is definitely wrong, then, and it's not just gearing. I'll ask again, is it an auto? Is it shifting correctly? Is it slipping?
I'd pull the plugs and make sure they all look like they're firing correctly, I'd check the timing, I'd test out the TPS and AFM, I'd jump the test port and pull the engine codes, I'd be taking it down to a muffler shop to get the cat checked, etc.
Old 05-18-2013, 10:05 AM   #9
Jay238's Avatar
Law Enforcement:
It is the auto. We went an got a a whole new exhaust System made yesterday and that helped a lot. Before it was only muffler, nothing else. Tearing into her today for The rest
Old 05-25-2013, 02:53 PM   #10
GRIZrunner is on a distinguished road
GRIZrunner's Avatar
GRIZrunner's Tacoma Gallery
Id check the timing also
Old 05-25-2013, 03:08 PM   #11
This is my derpawayinator!!!!!
NelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shed
NelsonTacoma's Avatar
NelsonTacoma's Tacoma Gallery
My dad and I just recently put a rebuilt 3.0 in my sisters 92 4x4 4runner. It's also an auto. It's just slow. We removed the cats and even put on smaller tires. Nothing has helped. After asking the same question here that you asked we just pretty much gave up.
http://www.tacomaworld.com/forum/4ru...eed-ideas.html
I recently bought a 96 4runner with the 3.4 and it has TONS more power.
Old 05-30-2013, 08:09 PM   #12
Jay, any updates?
Old 05-30-2013, 10:05 PM   #13
Jay238's Avatar
Law Enforcement:
Nope, tried looking at everything listed, still a dog. Chalking it up to gutless engine.
Old 06-01-2013, 01:52 PM   #14
Sadly that's the decision my dad and I came to. If we knew we probably would have scrapped the truck and bought a newer one. My dad spent like $2k rebuilding the motor and buying a used tranny. What a waste.
1995.5 Tacoma, Any problems? NJTacoV6 1st Gen. Tacomas 15 05-06-2014 03:22 PM
1990-1995 4Runner Service Manual & Wiring Diagrams PDFs pippen 4Runners 1 08-15-2012 01:19 PM
FS: tweeter pods from 4runner to your 1995-2004 tacoma freshman 1st Gen Tacoma Marketplace 2 02-04-2012 12:25 AM
1995 advice Stuart4x4x41995 New Members 1 07-10-2011 09:22 AM
1995-2004 Tacoma and 1996-2002 4Runner Parts yotaluver Buy / Sell / Trade 27 09-08-2010 11:19 AM
