-   4Runners (http://www.tacomaworld.com/forum/4runners/)
-   -   Reading Trouble Codes? (http://www.tacomaworld.com/forum/4runners/186292-reading-trouble-codes.html)
hetkind 11-05-2011 03:46 AM
SIL bought a beat to sh*t, 1990 4Runner and the check engine lights keeps coming on. Is there an easy way to read the error codes so I can fix the problem and get the light off? The previous owner didn't remove the skid plate to change the oil so I thought there was a major oil leak when I first saw it, and then there is a clogged cat, and the exhaust system is missing after the rusted out muffler.
It took a whole can of intake manifold cleaner to get the throttle body to open and shut easily, not to mention the air cleaner looked like a black beehive. The receiver draw bar had to beat out with 4lb hand sledge...
Howard
steezemcqueen 11-05-2011 08:05 PM
http://www.yotatech.com/f116/check-e.../#post50374865
:cheers:
hetkind 11-06-2011 03:16 AM
thank you...I will see if I can pull the codes today.
Howard
