3rd gen seat swap question
Discussion in '4Runners' started by NelsonTacoma, Jan 24, 2014.
  1. Jan 24, 2014 at 5:25 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I badly need to replace my front seats on my 96 4Runner. I found a set through a friend for $100 but they are out of a 93. Does anyone know if they will fit? I found a few threads mentioning it, but no one ever confirmed if they do. Any help would be appreciated.
  2. Jan 25, 2014 at 10:14 AM
    NelsonTacoma
    Tucson, AZ
    Bump
    Anyone?
  3. Jan 25, 2014 at 10:16 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    No Idea man. Maybe try t4r or something...I don't think something 10+ older is gonna fit very well. Where there's a will, there's a way, but I think you're best bet is a junk yard or something
  4. Jan 25, 2014 at 5:49 PM
    NelsonTacoma
    Tucson, AZ
    None of the junkyards around here have any seats that are in good shape. :(
    I bought them anyway. I plan on just swapping the seat tracks over somehow. The seats I got are in excellent condition for being from a 93. Really they are only 3 years older than my 4runner. I'll update on the progress if it does or doesn't work.
  5. Jan 25, 2014 at 6:11 PM
    VolcomTacoma
    Jeff
    NorCal
    well then just figure out the track system and you'll be good to go :D
  6. Jan 26, 2014 at 1:27 PM
    NelsonTacoma
    Tucson, AZ
    I also just realized the seat belt buckle is going to be an issue too. 2nd gens are mounted to the floor. 3rd gens are on the seat... This is going to be quite the project. I really want these seats to work they are so much more comfy than my current ones.
  7. Jan 27, 2014 at 6:10 PM
    NelsonTacoma
    Tucson, AZ
    So as it turns out, the solution to my problem was very simple. I just swapped over the 93 seat foam & fabric to my 96 seat frame. I started with the passenger seat so if I ran into any issues I could still drive the truck home from work. I had to make some minor adjustments here and there though. The side bolsters were a little different as well as the width of the seat bottom. All in all it turned out fantastic and I can't wait to finish it up by doing the drivers seat. I took a few pictures during the repair but had to stop so I could finish and get back to working on other peoples cars.....
    This is the drivers seat out of the 93. The tracks are different, plus there's no buckle.
    This is my drivers seat in the 96. Crappy fake leather covers and no padding or support. You can see the finished seat on the other side.
    This is my 96 frame with the seat back & foam removed.
    Here's the foam from the 96 seat. You can see the tears in the bolsters as well as the center back.
    Here is where I had to modify the foam a little. The bolster shape is a little different so I had to cut it so the frame would slide in. I worked rather well.
    Here's the seat after I installed it in the 4runner. It matches the interior pretty well and the seat is very comfortable. I wish I could have driven home on it.
    The best thing I found was that the headrest posts are the same width and distance apart so I reused the the post mounts from my 96 seat since the 93 post mounts don't work with the 96 frame.
    I didn't get to take pictures of the seat bottom transfer but it's pretty easy. I'll post some more pictures tomorrow of my drivers seat project.
  8. Jan 28, 2014 at 10:02 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I think you did an awesome job, turned out great.
  9. Jan 30, 2014 at 6:10 PM
    NelsonTacoma
    Tucson, AZ
    Just a quick update. I got the drivers seat swapped and installed. It had an issue I was not aware of but overcame it pretty easily. So the reason the seat sucked so bad was because the spring & grate assembly below the bottom cushion was trashed. I just swapped it over from the 93 seats and all was well, but it explains why the seat sank down so badly.
    Here's the finished product. I love my new seats. I can't beleive I drove on the crappy seats for a year....
  10. Jan 30, 2014 at 6:11 PM
    NelsonTacoma
    Tucson, AZ
    Thanks!!! I'm extremely happy with the results.
  11. Jan 30, 2014 at 6:46 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea, definitely looks good, brother
  12. Jan 30, 2014 at 7:34 PM
    NelsonTacoma
    Tucson, AZ
    Thanks!!
