Stock 6lug skid plate on 5lugger Taco
Old 11-28-2010, 02:04 PM   #1
05RedTaco [OP] 05RedTaco is offline
Nom Nom Nom
05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed
05RedTaco's Avatar
05RedTaco's Tacoma Gallery
Exclamation Stock 6lug skid plate on 5lugger Taco
I wanted to try this, I knew that most likely the bolt holes won't line up, however I was pretty certain that the skid itself will fit. I researched and some people make skid plates for 5lugger Tacos, however those can be expensive... around $200 shipped, that definietly wasn't in my budget....
I posted a thread in the AZ section asking if anyone has stock 6lugger skid plate laying around. I wanted to come by and test fit the skid, just to see if it works. Even used the stock 6lugger skid plate is cheaper than custom 5lug skid plate.
Fellow member OH-MAN pm'd me and told me he has two stock 6lug skid plates laying around and that I can have one. I was stoked! I came by the next day and got the skid plate from him. Many, many thanks to OH-MAN for giving me the skid plate! Thanks to him I was able to verify that stock 6lugger skid will fit 5lug Tacos!
Then I went to my buddies house where we talked about how to mount it. No holes lined up. So this had to be completely custom. I figured out where I want the mounting points to be. Two in the back and one up front. The reason for one up front, is because nowhere else on the front the skid touched in large enough area to drill & get a sturdy bolt there. I got Drill bit for hard metal from ACE hardware and some 8.8grade hex bolts, washers & nuts.
Install was easy. I had my friend hold the skid tightly to the truck, while I drilled. It turned out great and it should provide some protection. I am not certain about just one bolt up front, however I think it will be ok.
Now for pictures;
The skid even clears the front sway bar, gotta make sure that the skid is centered and that same amount of clearance is on both sides of the front sway bar.
In this picture you can clearly see the one bolt up front and two bolts in the back.
Old 11-28-2010, 02:14 PM   #2
OH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shed
OH-MAN's Tacoma Gallery
Nice job !!
Glad you could use it.
Old 11-28-2010, 02:16 PM   #3
Thread Jacker
schiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shedschiz94 is one of the sharper tools in the shed
schiz94's Avatar
schiz94's Tacoma Gallery
thats sweet. i will keep this in mind.
Old 11-28-2010, 08:20 PM   #4
113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed113tac is one of the sharper tools in the shed
113tac's Avatar
113tac's Tacoma Gallery
thats pretty sweet, i had no idea you could do that! ill probably do that in the future
Old 12-05-2010, 11:56 AM   #6
113tac's Avatar
did you have to remove the two bars that are in the same location?
Old 12-05-2010, 12:14 PM   #7
Nom Nom Nom
05RedTaco's Avatar
Nope. I didn't remove anything, just screwed it in...LOL
Old 12-05-2010, 12:16 PM   #8
113tac's Avatar
oh okay thanks
EDIT: what type of drill did you use?
Old 12-05-2010, 12:27 PM   #9
Nom Nom Nom
05RedTaco's Avatar
oh okay thanks
Just a regular cordless Black & Decker drill. Make sure to get drill bit for hard metal.
Old 12-05-2010, 12:37 PM   #10
113tac's Avatar
oh alright, i might get a skid that i found for sale on here
Old 12-05-2010, 04:58 PM   #11
Nom Nom Nom
05RedTaco's Avatar
Cool! If you do, post pictures of how you mounted it!
Old 12-05-2010, 07:02 PM   #12
113tac's Avatar
alright man i will if i do end up getting the skid
Old 04-22-2011, 02:10 AM   #15
Don't give up here just yet
2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed
2TRunner's Avatar
2TRunner's Tacoma Gallery
This is what I was looking for.
Wanted to see this thread before I went ahead and pulled the trigger on having a 6 lug skid shipped out to me from Cali (I'm in Ohio).
OP, with the truck parked, are you able to tell that there is a skid plate under it?
Old 04-22-2011, 09:26 AM   #16
Nom Nom Nom
05RedTaco's Avatar
Yes! It looks installed the same as on any 6lug Taco...
Old 04-22-2011, 08:06 PM   #17
2TRunner's Avatar
Awesome Opposum.
Old 10-12-2013, 12:47 PM   #19
Braking Bad is on a distinguished road
Braking Bad's Avatar
Braking Bad's Tacoma Gallery
I did this today. I had bought one thinking that I would bolt right up. It has been sitting around for almost a year.
I cut some slots in the plate and bent down the tabs on the braces so they would fit through and support each side. Then Bent them back up once it was on.
Probably would have been better to drill through and then tap the holes in the braces.
I dont know how you had the patience to drill the braces I just used hose clamps.
And I cut away some on each side to clear the x runners sway bar.
Stock skid plate 05RedTaco Arizona 8 11-25-2010 11:53 AM
Stock 6lug skid plate on 5lug taco 05RedTaco 2nd Gen. Tacomas 1 11-06-2010 11:30 AM
need simple skid plate for '10 stock taco cactuscorn 2nd Gen. Tacomas 19 10-21-2010 06:38 PM
FS--Stock leaf+aal, Stock rear shock, stock skid plate FixedTRD Buy / Sell / Trade 30 10-11-2010 06:12 PM
does the silver toyota skid plate go over the black stock sport skid plates? larry2375 2nd Gen. Tacomas 1 02-06-2010 06:27 PM
