Largest tire size on stock 5 lug
Old 08-28-2013, 05:03 PM   #81
jballfl is on a distinguished road
jballfl's Tacoma Gallery
Got the 235 / 75 / 15
great looking tire - I got them at walmart but beware, walmart wont install because they don't match the original tire size -- but no worries just to sears, they will take your money and do a nice job. no lift no rubbing , the tires , stock rims, truck look 15 times better... wondering why Toyota didnt go with this size from the beginning. 235/75/15
pics to follow
Old 08-29-2013, 10:04 AM   #82
Bowace is on a distinguished road
Bowace's Tacoma Gallery
rim size
What is the rim width that you put those bigger tires on. Mine are the stock 6" wide steelies and am concerned that the 235 won't fit on them very well. I think they will fit but just not the way they should. 6' is a bit narrow but 215 or 225 should be good, ....yes, no, maybe? Mines an 04 taco ext cab 4 cyc, 5 speed 2WD and it too came with 205x75x15--trailer size tires. I really need bigger tires but don't want to go with a lift or buy wheels just at least 215s.
Old 09-01-2013, 11:04 PM   #83
Mr.Schertz is on a distinguished road
Mr.Schertz's Avatar
Mr.Schertz's Tacoma Gallery
I ended up going with the 235 75 15 Yokohama Geolanders. Truck looks good and drives good. I was gonna do the fat bobs lift but im not sure. these new tires give it a good look.
Old 09-03-2013, 12:49 PM   #84
I have the stock 15 inch rims -- the 235 fit awesome -- ill post pics as soon as I remember to take a pic ...
Old 11-29-2013, 03:59 PM   #85
levi is on a distinguished road
levi's Tacoma Gallery
So I know there is already alot been said about 2wd base tacomas.
But I have an 07' tacoma access cab 4 cyl. I got the truck for the MPG so I want as little rolling resistance as possible but I also like the bigger wheel look. I am looking at the Firestone Destination Le 2 in the 215/75r15.
Does this sound like a good choice??? Thanks, first post!!
Old 12-02-2013, 11:00 AM   #86
Esau is on a distinguished road
Esau's Tacoma Gallery
Anybody knows what kind of offset could i put to my 5lug so it could be stickingout a little out off my fender im not trying to get it to sticking out way to much
Old 12-03-2013, 10:01 AM   #87
LEVI, If I had an 07 I believe that I would go with at least 16 rims for my tires but if yours came with 15s - 225/75/15 will fit those rims.
Old 12-15-2013, 10:38 AM   #88
biker105nn is on a distinguished road
biker105nn's Tacoma Gallery
Do those raise the truck up a little and make it ride taler than the stock tires?
Old 12-17-2013, 09:46 AM   #89
@biker105...
if you are asking about the 235/75/15 ... yes they make the truck look tall, about 2 inches taller and looks great... it doesn't look too rednecky but just tall enough to look a lot better then the stock tires... ill post some pics this week...
cheers
Old 12-25-2013, 07:47 PM   #90
@jballfl,
That would be awesome! I am in the market for new tires, I want to keep the stock 15 rims, but want bigger tires to lift the truck up a little bit. It rides so low it's ridiculous, and I want it to ride like my old 01 TRD quad cab. It would be awesome if it lifts it a couple inches like you said! Pics would be awesome! Any suggestions on tires? I was thinking the all terrains from bf Goodrich, but do they make those in 235/?/15? Also, do they rub?? Like will I notice it and be annoyed?
Old 12-30-2013, 01:33 AM   #91
aggiepack is on a distinguished road
aggiepack's Avatar
aggiepack's Tacoma Gallery
@biker105 here's my 08 with the readylift kit and 235/75/15 with the stock rims.
They will not rub even without a lift. If you go larger you're gonna have to do the black box mod. I had 225's before the 235's and I can tell you for a fact that the 235's look AND feel better.
Here's a picture from the rear. You can tell they fill the wheel well a lot better than the stock 215's, but I've seen stock's with 245s and they fill a bit nicer imo. Honestly, I sometimes wish I went 245's for the little difference in height and fill alone, but I am more than content with the 235's. I think it was also mentioned before, but with the 235's and a readylift kit (spacer and an extra leaf) your speedometer will be just fine. Parked next to a prerunner without any mods, they barely and I mean barely, sit a bit lower looking from the front.
Old 12-31-2013, 09:03 AM   #92
Looking good aggiepack -- @biker I got the goodyear wranglers at walmart - walmart wont install them because they aren't the stock size but I just drove them to sears and they put them in no problem... they have the big thread and look good.
Old 12-31-2013, 02:06 PM   #93
Pics
my tires -- way better than stock
Largest tire size on stock 5 lug-tire-1.jpg   Largest tire size on stock 5 lug-tire2.jpg
Old 01-16-2014, 06:29 AM   #94
320BusDriver is on a distinguished road
320BusDriver's Avatar
Air Force: Retired Pilot
320BusDriver's Tacoma Gallery
New Tires/Wheels on 2010 Access Cab
This is a picture of my 2010 Access Cab with 16" Enkei Wheels and 235/65/16 Firestone Destination LE2's. (package deal from Tire Rack). Truck sits 1" taller, speedo now correct (was about 5% fast before), wheel wells filled out nicely and truck runs smooth on the new setup (Tire Rack does road force balancing). Mileage about the same when I factor in the odometer difference, avg 23mpg. Youd don't need to go all the way to 235/75's to get a nice look.
Old 01-16-2014, 01:37 PM   #95
lloyd is on a distinguished road
lloyd's Tacoma Gallery
I just put some 18x8 wheels with 40mm offset. The tires are 235 55R 18. They fill the wheel well up nicely without sticking out. The speedo is now perfect.
Old 01-06-2015, 09:33 PM   #96
jdhreiss is on a distinguished road
jdhreiss's Avatar
jdhreiss's Tacoma Gallery
I have 11.50 32" on stock wheels on my unlifted 99 trd. Light rub on frame at full lock.
Joe R.
Old 01-18-2015, 10:30 AM   #97
ferdie is on a distinguished road
ferdie's Tacoma Gallery
if i do the black box mod can i fit a 255x70x16 without a lift
LARGEST SIZE TIRE skw Wheels & Tires 15 12-11-2011 07:30 PM
largest tire size? bosoxwon09 Wheels & Tires 3 01-15-2011 03:09 PM
largest tire size on stock 5 lug Taco515 Wheels & Tires 2 12-09-2010 03:00 PM
Largest 09 tire size TRIMM826 Wheels & Tires 5 01-29-2010 02:48 PM
largest tire size takaya49 Wheels & Tires 7 01-24-2010 04:25 PM
