5 lug driveshaft question?
Old 06-22-2011, 08:12 PM   #1
bills yota 2wpeel has a spectacular aura aboutbills yota 2wpeel has a spectacular aura about
bills yota 2wpeel's Avatar
bills yota 2wpeel's Tacoma Gallery
Could somebody take a picture of the area where the rear driveshaft slides into the transmission on their 5 lug standard cab manual 05up tacoma? I need to know how far into the transmission the driveshaft should normally be.
Im having problems with a leaking seal and looseness on the output shaft of the transmission probably caused by my lift and driveshaft angle. I think the driveshaft is too far to the back now. I swapped the center section with one from a older truck with different gearing too. Thanks for any help.
Old 06-25-2011, 09:31 PM   #2
Joels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to behold
Joels98taco's Avatar
Joels98taco's Tacoma Gallery
that older 3rd member could be your issue
Old 06-26-2011, 07:16 AM   #3
The center came from a '96 4x4 non ELD. I was told the '08 and it were both the 8.4 diff. They looked identical, but I did have to swap the pinion flange from my '08. Any ideas? Thanks.
Old 06-26-2011, 03:29 PM   #4
what im thinking is that the 3rd member you swapped in may be slightly shorter than the one you took out causing the driveline to be pulled back
Old 07-12-2011, 06:24 PM   #5
NakedTacoma is a glorious beacon of lightNakedTacoma is a glorious beacon of lightNakedTacoma is a glorious beacon of lightNakedTacoma is a glorious beacon of lightNakedTacoma is a glorious beacon of lightNakedTacoma is a glorious beacon of light
NakedTacoma's Tacoma Gallery
Old 07-12-2011, 06:50 PM   #6
i dont think so unless he has linked suspension .... i have a race pack and at full droop the driveshaft pulls out but no issues and im sure my DS is coming farther out than his. the pinion/ds angle would be my first guess.
To the OP do u have any DS vibrations?
Old 07-15-2011, 08:50 PM   #7
No vibrations from the driveshaft at all. Looking at your picture, id say the slip yoke looks right. Im thinking now that a bad U-joint on the differential side may have helped cause the problems on the transmission side. I replaced the seal on the trans and both driveshaft u-joints, but the transmission is still leaking. I put 3* shims on the axle to help the angle.
I thought maybe I could just buy the slip yoke and it would be tighter on the splines, but the dealer shows the entire driveshaft sold together. I guess I'll just have to add oil and hope the output shaft bearings dont go bad on the transmission.
Old 07-16-2011, 12:34 AM   #8
that sucks man. hope you get it fixed soon
Rear Driveshaft Question bellassaiw10 1st Gen. Tacomas 9 01-03-2012 09:12 PM
Stock driveshaft angle question crashnrondo 2nd Gen. Tacomas 0 02-11-2011 01:47 PM
Question about about driveshaft tacoman68 Long Travel Suspension 3 01-23-2011 09:05 PM
driveshaft spacer question 08pretaco 2nd Gen. Tacomas 18 09-09-2009 03:44 PM
driveshaft lube question asdfjkl 2nd Gen. Tacomas 7 02-13-2008 11:14 AM
