Need help with 1st gen 5-lug lift
Old 11-29-2011, 12:36 AM   #41
SCUMBAG CUSTOMS
Scummy will become famous soon enough
Scummy's Avatar
Scummy's Tacoma Gallery
I have the kit on my truck your talking about but its definitely not a 6indick lift. I think its more 4in. The pics are one my profile. But look at how bad the coils are flexed. If you do get this kit I suggest you spend a lil money and get some coilovers and have a fab shop build you some mounts. I also am running 32/11.5-15 but definitely need the flared fenders to cause it'll make it sit wider too.
Old 11-29-2011, 11:02 AM   #42
Gear Head
5LUGTACO is on a distinguished road
5LUGTACO's Avatar
5LUGTACO's Tacoma Gallery
The cross-shafts are the two bars that bolt to the coil bucket that's what the Uca pivots on. The picture I showed was taken during install, notice the ball joint isn't even bolted up yet. I cranked it to give me a 6" lift with the spindles. The tc cross shafts were only designed to work with the taquito kit I didn't know that at the time of purchase but managed to run them for a bit. I also removed that stabilizing bar and welded a .120 wall cromoly tube in its place and a plate for extra strength. I then drilled the existing hole to 1/2" and used a heim joint. It was pretty cool but unfortunately don't have pics of that.
Old 11-29-2011, 11:22 AM   #43
Gear Head
5LUGTACO's Avatar
My truck with the fabtech lift still on
Old 11-29-2011, 12:48 PM   #44
87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of
87xjmike's Avatar
87xjmike's Tacoma Gallery
ok, got it... Yeah i didn't know tc would sell the cross shafts seperately. Did you see any advantage to running them over what the downy kit came with? Can't really tell but they look a little beffier than what i have (which i think is a stock crossshaft)
I'm not a fan of having to space the crossshafts out from the coil bucket to correct camber but it had to be done.
I had to relocate my stabalizing bar on the driver side, grind down a tab so it wouldn't hit the steering coupler and weld it in closer to the coil bucket. Seems to hold up fine.
I didn't know fabtech made arms for the 5 lug, do you like it better? Pics of susp...?
I get a pretty loud crack/pop from the front susp. while turning in reverse, All my bj's are new so i think i'm just going to go in a replace all my bolts with grade 8 and make sure everything is snug, My cheap ass buddy that installed it when the truck was his used shotty looking hardware thats not long enough and a low grade...
Old 11-29-2011, 01:53 PM   #45
Gear Head
5LUGTACO's Avatar
The picture above is when I had the 3" lift from fabtech. It consisted of fabtech Uca coils and shocks. I hated it and installed that Downey kit you have later on. I just wanted to show a picture of my old truck
Old 11-29-2011, 01:55 PM   #46
Gear Head
5LUGTACO's Avatar
Tc cross shafts are way beefier for sure but I kinda Mickey moused it to fit. Tc arms are wider so I used three washers on each side to make up the difference
Old 11-29-2011, 02:30 PM   #47
87xjmike's Avatar
ok cook, thanks for the response, i didn't notice you have a 06 now and no longer have the 1st gen.
Overall i'm reletively happy with this quirky little downy kit, i'm sure it handles better than most coil set ups, obviously not better than an LT coilover but it's aight.
Old 11-29-2011, 05:27 PM   #48
Gear Head
5LUGTACO's Avatar
Especially for the price you got it for
Old 11-29-2011, 07:13 PM   #49
Joels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to beholdJoels98taco is a splendid one to behold
Joels98taco's Avatar
Joels98taco's Tacoma Gallery
theres a local shop here that will make chromoly cross shafts for the uca for 350 and you wont need to do the washer thing. they would be a stock replacement. ill probably pick some up when i get the money
Old 11-30-2011, 09:50 AM   #50
87xjmike's Avatar
That'd be sweet, any pics of what they've made?
Old 11-30-2011, 03:53 PM   #52
87xjmike's Avatar
on their site. they have made the shafts for the pick ups
http://www.obsessedmotorsports.com/T...g_spindle.html
most of they're pics don't work. sounds like cool stuff though
Old 11-30-2011, 11:19 PM   #55
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
the issue with the 5 lug is mostly the lower ball joint bracket, and the frame bowing in. other than that things are fine. If you want to get into nitty gritty, nothing on the truck is ever strong enough lol!
Old 12-05-2011, 10:56 PM   #56
i think i bent my uca cross shafts already...
Old 12-06-2011, 09:19 AM   #57
87xjmike's Avatar
Oh dang
Pics?
Old 12-06-2011, 11:10 AM   #58
Trifenix's Avatar
whattt how? lol mine are still fine....i think...*runs to go check*
Old 12-06-2011, 02:56 PM   #59
haha i think i really did my tires are getting really chewed up from the inside and i got it aligned after the lift. pics later
Old 12-09-2011, 06:18 PM   #60
dont you have tc cross shafts?
oh haha and i hit a deep dip on a daily basis at 40+ mph
1st Gen 5 Lug Lift, Any Pics? STOCKTRD 5 Lug 45 03-29-2012 10:53 AM
Do you like this 6 lug 1st gen bumper? Beefed Taco 1st Gen. Tacomas 6 01-12-2012 06:42 PM
How Different is a 1st gen PreRunner to a Five Lug jcemitte 5 Lug 3 07-20-2011 09:33 PM
WTB 1st GEN lift. Coilovers or Spacers 6 lug tacos89 Buy / Sell / Trade 1 11-26-2009 01:27 PM
WTB 1st GEN lift. Coilovers or Spacers 6 lug tacos89 Buy / Sell / Trade 0 09-25-2009 12:49 PM
