what is the max offset can we use for our 15x7, 5-lugs?
Old 01-03-2012, 07:03 PM   #1
fastrope [OP] fastrope is offline
fastrope is on a distinguished road
fastrope's Tacoma Gallery
what is the max offset can we use for our 5-lugs?. .does anyone know of any that have gone very agressive?
example:
15x9.5, +12 or 4.5" back space, etc..
Tires:
255/70/15?
need some advise and opinion on maximum wheel and tire size
Old 01-03-2012, 07:24 PM   #2
Bosmob is a glorious beacon of lightBosmob is a glorious beacon of lightBosmob is a glorious beacon of lightBosmob is a glorious beacon of lightBosmob is a glorious beacon of light
Bosmob's Avatar
Bosmob's Tacoma Gallery
example:
Tires:
255/70/15?
I'm running a 15X7 with 3.75 backspacing and a 31" tire.
I had to grind material off of the calipers, remove the "blackbox" and trim the inner fender liner.
I don't know if that helps but there you go
Old 01-03-2012, 08:18 PM   #3
Bosmob,
Thank you for your help... im planning on 15x8 with 4.5" back space but not sure if this will work. I want the wheel/tire to flush with fender and not stick out..
Old 01-09-2012, 02:31 AM   #4
any more help guys?
Old 01-21-2012, 09:08 PM   #6
KDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shedKDogg311 is one of the sharper tools in the shed
KDogg311's Avatar
Name: K H I E M ™
KDogg311's Tacoma Gallery
any more help guys?
Im runnin 15x8 rims with 3.75 backspacing ... 30x9.5 tires ... 3mm spacers in front to clear the calipers
they stuck out about an inch or so from the fender
Old 03-17-2012, 10:07 PM   #10
348rr808 is on a distinguished road
348rr808's Tacoma Gallery
Kdogg, so you just used the spacers to clear the caliper? Didn't need to grind them down or anything?
Truck looks good!
Old 03-19-2012, 02:27 AM   #11
KDogg311's Avatar
Name: K H I E M ™
Truck looks good!
Thanks!
Nope, no grinding or sanding down or anything. I just check on my the lugs every so often
Old 05-27-2012, 04:38 AM   #12
Thanks for the help... here is my outcome...
Old 09-18-2012, 04:43 PM   #13
endlesstacoma is on a distinguished road
endlesstacoma's Tacoma Gallery
what set you end up using?????????
16x8, +0 offset (4.5" offset) - what tires can I fit?? mlevinson Wheels & Tires 14 04-14-2012 06:05 AM
0 offset wheels don't fit? -22 offset pictures DNG Wheels & Tires 9 10-09-2011 01:57 PM
IS THERE A MAX. OFFSET A 2ND GEN CAN HANDLE???????? Detective_Dan Wheels & Tires 29 01-12-2011 10:34 AM
Rims: Positive Offset v. Neg. Offset SLOH 2nd Gen. Tacomas 17 09-04-2009 05:01 PM
Upgrading from 5 lugs to 6 lugs on a 2001 Tacoma! Tacoma_01 Technical Chat 0 09-02-2008 11:07 AM
